System Variable or Diesel Expression Question
I need to make a huge amount of sheets with match line and I wanted to know if I could use this expression:
%<\AcVar ctab \f "%tc1">%
and make it add or subtract a 1 from the number it outputs.
My sheets are all named 1,2,3,4,etc
The match line would reference the sheet before it and after it.
Is there a Field System Variable or Diesel Expression to accomplish this?
Thank you!
ronjonp
Quick test and %<\AcVar ctab>% + 1 works in the formula field.2018-05-31_9-01-34.png
