Switching between Drawings
Message 1 of 18
Is there an easier way to switch between open drawings in 2000 than going to
the Window pull-down. I can't seem to find it in Help and I've tried all
the combinations of F keys I can think of. I would create a new accelerator
key if knew what to tell it to do.
Thanks for your help.
Replies (17)
Message 2 of 18
Ctrl F6
"Jack Gill" wrote in message
news:748ACFA117B57004086B38B5A31AFF69@in.WebX.maYIadrTaRb...
Message 3 of 18
Also Ctrl Tab (easier one-handed)
-doug
"Doug Barr" wrote in message
news:6D38A6174430C2EE635AFE8878714EC1@in.WebX.maYIadrTaRb...
> Ctrl F6
Message 4 of 18
Ctrl + Tab
to
accelerator
Message 5 of 18
Jack:
Try....
Ctrl+Tab & Ctrl+Shft+Tab
Victor
Jack Gill wrote in message
to
accelerator
Message 6 of 18
Jack,
CTRL TAB might help especially if you have a few files open.
There are also some document managers available free but they take up
some screen space.
Doug
Message 7 of 18
Alt + W , then 1 or 2 or 3.....
PIII 550, 256 MB, NT4, SP6; A2002, Express Tools V9
Kent Elrod, Facilities Design
SUMCO USA
Albuquerque, New Mexico
kent.elrod@nospam.sumcousa.com
to
accelerator
Message 8 of 18
On Fri, 1 Mar 2002 10:49:56 -0800, "Jack Gill"
Ctrl+Tab will do this.
Ian A. White, CPEng
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Fax: +61 2 9622 0450
Home Page: www.wai.com.au
Message 9 of 18
On my system that requires
Alt + W + Down arrow, then 1, 2 ,3........
That is also assuming there is no other pull downs that start with 'W'.
-Jason
Member of the Autodesk Discussion Forum Moderator Program
Message 10 of 18
CTRL+Tab works for me.
___
to
accelerator
Message 11 of 18
On my system it is Alt + W, then 1, 2, 3 ...
There should only be one pull down that is defined to use W in order for the
Alt + W to work.
SUMCO USA
"Jason Piercey" wrote in message
news:9CD56C42B53DC0D5FFD016C6D64D1354@in.WebX.maYIadrTaRb...
> -Jason
Message 12 of 18
Why not use Ctrl+Tab and Ctrl+Tab+Shift as it will behave
the same on all systems, it can be used with 1 hand, it's
faster, and this same functionality exists in *most* MDI
applications?
Actually Word is the only application I've found that
doesn't do this. And MS has admitted this is a bug in Word
and that they are not going to fix it.
Kevin Nehls
"Kent Elrod" wrote in message
news:F974903A3691E952253056AEB08861A9@in.WebX.maYIadrTaRb...
W in order for the
> Alt + W to work.
Message 13 of 18
"Docbar" is my favorite way to switch between open documents. This is a
program from CADwerx that runs inside AutoCAD and creates a toolbar like
object which displays a preview image and filename of all open documents. I
like to locate my Docbar in the upper left hand corner of the screen, above
the menu bar, and just left of Windoze minimize/maximize/close button. It
doesn't take up any valuable screen space there. Freeware. 'Tip of the
O'hat to Byron Blattel @ CADwerx
http://www.cadwerx.net/
S.D.
to
accelerator
Message 14 of 18
Not that this is the Word NG, but Ctrl+Tab is the only way I know of to get a tab within a table cell.
John Uhden, Cadlantic/formerly CADvantage
[ mailto:juhden@cadlantic.com ]
[ http://www.cadlantic.com ]
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
"Kevin Nehls" wrote in message news:3483E818BB012BA4A258E467C971F970@in.WebX.maYIadrTaRb...
> applications?
> Kevin Nehls
> W in order for the
> > Alt + W to work.
Message 15 of 18
Kevin
"Kevin Nehls" > wrote in message
Alt+W should work on all systems, if someone has changed the menu to have
more than one Alt+W then ehty need to change it.
Alt + W is a one handed command, and reaching for 1,2,3, is with in very
easy reach
> it's faster,
If you have a large number of files open, then Alt + W , then a number, will
get you to the file you want very quickly, without having to page through
several files to get there. Using the file name will make sure you are in
the file you think you are in. If you are zoomed in on several drawings and
the Alt +Tab you can't be as sure you are in the drawing you hope you are
in.
> applications?
Alt + W works very well in Excel and Word.
Kent Elrod
Message 16 of 18
Yea, but they could very easily do an "if in table, then do
tab, else change open docs".
It was on one of the MS newsgroups that I read they had
admitted this is a bug in Word and that they are not
planning on fixing it. At least with Office 2000+ you can
have multiple documents (Word and Excel, and others I
suppose) separate from the "main" window, so you can at
least use Alt+Tab.
Kevin Nehls
"John Uhden" wrote in message
news:E2793ED898B168D095585F48B690958A@in.WebX.maYIadrTaRb...
Message 17 of 18
Kent,
Good points. I'm just use to using ctrl+tab as I don't have
that many dwgs open at a time, maybe 5 max. And I use it
everyday in several apps that don't have a "Window"
pull-down.
Kevin Nehls
news:AE8B722398B10FA927E7FCF3F91117C9@in.WebX.maYIadrTaRb...
then a number, will
to page through
sure you are in
you hope you are
> in.
Message 18 of 18
Jason
if there were other such pulldowns, that would indicate extremely poor
programming practice on the part of the author of the partial menu that must
have been added wouldn't it? (or heavens forbid the modifier of the maun
menu)
cheers
Steve
| -Jason
