Surface from 3 points
BB8x
Message 1 of 14
BB8x
Hello
Maybe someone has or can write something for me. I need to draw surface from 3 points (triangle, planar).
I can imagine this like that:
1) I do click 3 points in the drawing
2) Lisp creates 3d poly or 3d face (what is easier)
3) Lisp turns 3d poly or 3d face into surface
4) Lisp deletes base 3d poly or 3d face
Accepted solutions (3)
Replies (13)
Message 2 of 14
doaiena
Here you go.
(defun c:test ( / p1 p2 p3 lastEnt)
(setq p1 (getpoint "\nPick first point: "))
(setq p2 (getpoint "\nPick second point: "))
(setq p3 (getpoint "\nPick third point: "))
(if (and p1 p2 p3)
(progn
(if (vl-cmdf "3dface" p1 p2 p3 "" "")
(progn
(setq lastEnt (entlast))
(vl-cmdf "convtosurface" lastEnt "")
(vl-cmdf "erase" lastEnt "")
(princ)
);defun
Message 3 of 14
Sea-Haven
A surface is a more plural answer of multiple 3dfaces, so why convert ? Are you trying to make a multi 3dface surface if so just google for Triangulation it will make a surface form points.
Message 4 of 14
BB8x
Thanks doaiena lips works great
Usually I do triangulation, but sometimes is easier to draw than delete unwanted elements from triangulation
Message 5 of 14
_gile
It would be much cheaper to simply do some geometric computation.
You can easily calculate the signed area of a triangle (it's equal to the half of the Z coordinate of the cross product of (p1,p2) and (p1,p3) vectors). The sign of the result also indicate if points are clockwise or not.
(defun signedArea (p1 p2 p3)
  (/ (-	(* (- (car p2) (car p1)) (- (cadr p3) (cadr p1)))
	(* (- (car p3) (car p1)) (- (cadr p2) (cadr p1)))
     2.0
(defun c:test (/ p1 p2 p3)
  (and
    (alert
      (strcat
	"Area = "
	(rtos (abs (signedArea p1 p2 p3)))
	"\nPoints are "
	(if (minusp (signedArea p1 p2 p3))
	  "clockwise"
	  "counterclockwise"
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 6 of 14
john.uhden
BTW, if you're looking to shave off a few nanoseconds, I think I found years ago that multiplying by 0.5 is faster than dividing by 2.
John F. Uhden
Message 7 of 14
braudpat
Hello @john.uhden
Your answer is THE BEST !
THE HEALTH (Stay Safe), Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 8 of 14
john.uhden
Yes, well, after enough millenia, those nanoseconds can add up, maybe to as
much as a full blink of an eye. *;)*
John F. Uhden
Message 9 of 14
diagodose2009
Can you extend this routine?
;; Revision :07/03/2020 @Anonymous:44
(defun c:fc1 ( / p1 p2 p3)
(progn
       (setq p4 (getvar "VIEWCTR"))
       (if (and p1 p2 p3)
       (progn  (setq CmColor 1)
               (entmakex (list (cons 0 "3DFACE")
                         (cons 100 "AcDbEntity")
                                    (cons 67  0)
                                    (cons 8 "0")
                               (cons 62 CmColor)
                           (cons 100 "AcDbFace")
                             (cons 10  p1)
                             (cons 11  p2)
                             (cons 12  p3)
                             (cons 13  p3)
                                   (cons 70 0)))
               (princ)
                                    (cons 67  0)
                                    (cons 8 "0")
                               (cons 62 50)
                             (cons 10  p1)
                             (cons 11  p2)
                             (cons 12  p3)
                             (cons 13  p4)
                                   (cons 70 0)))
               (princ)
) ; end eMaker
Message 10 of 14
_gile
Sorry, I do not understand what you mean.
Gilles Chanteau
GileCAD
GitHub
Message 11 of 14
Sea-Haven
You mean repeat
(while (setq p1 (getpoint "\nPick first point: "))
extra close bracket at end
               (princ)
Message 12 of 14
BB8x
Hello again
Is there a chance to upgrade this lisp? For now creates surfaces. Would be possible to create surfaces OR mesh OR 3d solid (selectable)?
Lets say like this:
1) Lisp start
2) "What would you like to do you lazy ****? Surface Mesh 3dSolid"
3) Carry on with lisp
4) Chosen output
Message 13 of 14
Sea-Haven
Just go back to what I said get a triangulation routine pick all points, this makes 3dfaces. Google for next steps. They exist.
Message 14 of 14
BB8x
I know google knows that and been trying for few days. Thing is I did find only way to extrude or thicken surface. I wanted to keep in as it is (planar). All I am doing now is extruding for 0.0001 drawing units
