- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
O.k., So I'm about to delve into a routine to set support paths, templates, template paths, etc. and was planning on using the following to set paths for DGN mapping, Tool Pallete Paths, etc.
(setenv "SaveFilePath" (strcat "C:\\CAD Standards\\"))
I'm not sure what all the names are in quotes in (setenv but I happen to be looking at a profile (<<Default>>) in the Registry, specifically the general section. (for civil3d 2015)
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R20.0\ACAD-E000:409\Profiles\<<Default>>\General]
Is this the location where the path and template locations are found from the Files Tab in Options?
Are these keys the names used in quotes in (setenv ?
Here is a list of what I'm trying to change:
Enterprise CUI
Custom Icon Location
Printer Config Search Path
Printer Description File Search Path
Plot Style Table Search Path
Drawing Template File Location
Sheet Set Template File Location
Default Template File Name for QNEW
Default Template for Page setup overrides
Tool Palettes File Locations
DNG Mapping Setups Location
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
