sum items with the same cdr from a list
adaptacad
Message 1 of 27
adaptacad
Hello again everyone.
I try a list
ex:
(setq lst
    (52.7553 . "ITEM_1")
    (110.412 . "ITEM_2")
    (45.4596 . "ITEM_3")
    (54.023 . "ITEM_4")
    (65.2474 . "ITEM_1")
    (45.4596 . "ITEM_1")
    (45.4596 . "ITEM_2")
    (54.023 . "ITEM_4")
What is the best way to add the car of all items by associating the equivalent cdr:
((326,925 . "ITEM_1") ....
the same for all items
Replies (26)
Message 21 of 27
john.uhden
@luizhcastanho ,
Your inslaje.lsp doesn't have lines beyond 400-something (at least in NotePad).
AND, I did not use (nth 1 x).
I'm so sorry, but I guess I misunderstood your objective.
John F. Uhden
Message 22 of 27
luizhcastanho
I sent the wrong file
Message 23 of 27
john.uhden
@luizhcastanho ,
One major thing I see wrong is that my combine function returns your desired list, but you are not capturing the return because new is local to the function.
You have only (combine lst)
whereas you should...
(setq <combined> (combine lst)) ;; <or some other symbol name>
John F. Uhden
Message 24 of 27
luizhcastanho
Same error 😓
error: bad argument type: numberp: "5"
You understood my problem correctly, your function works.
I'm just not able to implement it in my Lisp because of me 😂.
It's strange that it returns an error that was expecting a numeric variable showing "5"
Message 25 of 27
luizhcastanho
in my lisp file the list
lst (list '("140" "9" "6.3" "N1") '("70" "6" "6.3" "N1"))
I'm trying to use atoi function
      (setq item (subst (apply '+ (mapcar '(lambda (x) (atoi (nth 1 x))) (cons item matches))) (atoi (nth 1 item)) item))
It doesn't show an error, but it doesn't add 🤣
Message 26 of 27
luizhcastanho
Worked, thanks
(defun combine (lst / item matches new)
  (while lst
    (setq item (car lst))
    (and
      (setq matches (vl-remove-if-not '(lambda (x)(= (nth 3 x)(nth 3 item))) (cdr lst)))
      (setq item (subst (itoa (apply '+ (mapcar '(lambda (x) (atoi (nth 1 x))) (cons item matches)))) (nth 1 item) item))
      (foreach match matches (setq lst (vl-remove match lst)))
    (setq new (cons item new) lst (cdr lst))
  (reverse new)
Message 27 of 27
john.uhden
@luizhcastanho ,
1st - I didn't recognize that this started back in July.  At that time, each item was just a dotted pair.
2nd - I had better check my code as to what is going wrong.
Oh, I think I see what it is.  This time your lst consists of items that contain 4 strings.
If you make up your mind I can fix my code (if necessary).
John F. Uhden
