Subtract text from a list
carlos_m_gil_p
carlos_m_gil_p
Hello boys how are you.
I have this list stored in a variable.
(setq lst-dxf-panel '(-3 ("MELIA_MPANE" (1000 . "Edge = Weft") (1000 . "Panel ID = 1.1"))))
As I can subtract the value of Panel ID
In this case "1.1"
Thanks for your help and excuse my English.
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
ВeekeeCZ
(substr (cdar (cddadr lst)) 12)
or
(substr (cdr (assoc 1000 (reverse (cadr lst)))) 12)
carlos_m_gil_p
Hi BeekeeCZ, How are you.
Thanks for your help.
I did the tests but if Panel ID is in the other side of the list does not work for me.
The Panel ID ubicaion may vary.
(setq lst-dxf-panel '(-3 ("MELIA_MPANE" (1000 . "Edge = Warp") (1000 . "Panel ID = 1.1") (1000 . "Description = created by mesh to panel, panel 1") (1000 . "Shear Strain =0.393%") )))
AutoCAD 2026
ВeekeeCZ
Try then... (substr (cdar (vl-remove-if-not '(lambda (x) (wcmatch (cdr x) "Panel ID*")) (cdadr lst-dxf-panel))) 12)
carlos_m_gil_p
It works very well, thank you very much.
AutoCAD 2026
john.uhden
(setq lst-dxf-panel
  '(-3
     ("MELIA_MPANE"
(setq ID
  (car
    (vl-remove-if-not
      '(lambda (x)(wcmatch (cdr x) "Panel ID*"))
;; returns (1000 . "Panel ID = 1.1")
(setq old (substr (cdr ID) 12))
;; returns "1.1"
(setq additive -0.1)
(setq new (+ (atof old) additive))
;; returns 1.0
(setq new (rtos new 2 1))
;; returns "1.0"
(setq new (cons 1000 (strcat "Panel ID = " new)))
;; returns '(1000 . "Panel ID = 1.0")
(setq new (subst new ID (cadr lst-dxf-panel)))
(setq rev-dxf-panel (cons -3 (list new)))
John F. Uhden
carlos_m_gil_p
Thanks john.uhden
AutoCAD 2026
