Visual LISP, AutoLISP and General Customization
Stripping...... :-) Characters from Layer Names
16 REPLIES 16
Message 1 of 17
411 Views, 16 Replies
Say I have layers named "LAYER1XX", LAYER2XX, LAYER3XX, etc. and I want to strip the "XX" from the layer names. How and what would be the best way to do this?
TIA
"Catch" Ya Later,
Tim
16 REPLIES 16
Message 2 of 17
You could use rename *xx to ?????? will strip the
xx.
Dave Alexander
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Say
TIA
"Catch" Ya Later,
Tim
Message 3 of 17
Dave,
Cool. But, if I wanted just to strip the XX from the layer name and leave the rest of the layer name as it was. I.e. LAYER1XX >>>> LAYER1 ????
"Catch" Ya Later,
Tim
Message 4 of 17
I thought that is what it does. I tested it and it
worked.
Dave Alexander
Dave,
"Catch" Ya Later,
Tim
Message 5 of 17
I have about 100 layer names to do this function to. 🙂
Message 6 of 17
If the layer names are not all the same length then
I would use rename ??xx to ?? and simply do another rename for layer names with
???xx and so on. Not automatic as with a specific rename lisp but what the hey,
low tech is not all that bad.
Dave Alexander
I
Message 7 of 17
Hey, I am low tech compatible. 🙂 Pretty much all the code I write is low tech. Good idea Dave. Thanks. Will work with that until...or unless I get another idea. Thanks.
Tim
Message 8 of 17
Their is really only one Religion, just different versions of it.
(defun C:lay_trim ()
(vl-load-com)
(vlax-map-collection
(vla-get-layers
(vla-get-activedocument
(vlax-get-acad-object)))
'(lambda (x)
(vla-put-name
x
(vl-string-right-trim
"XX";;;characters to trim (case sensitive)
(vla-get-name x)))
(princ)
Ken Alexander
Acad2000
Windows2000 Prof.
"We can't solve problems by using the same kind
of thinking we used when we created them."
--Albert Einstein
"TJARONIK" wrote in message
news:f1856a3.5@WebX.maYIadrTaRb...
> Tim
Message 9 of 17
Thanks Ken,
Dave Alexander
"Ken Alexander" wrote in message
news:D98BC4973CD6288CC797375169144A39@in.WebX.maYIadrTaRb...
> (vl-load-com)
> (vla-get-layers
> '(lambda (x)
> (vla-put-name
> x
> (vla-get-name x)))
> (princ)
> Ken Alexander
> Acad2000
> Windows2000 Prof.
> --Albert Einstein
> > Tim
Message 10 of 17
You're Welcome.
Ken Alexander
Acad2000
Windows2000 Prof.
--Albert Einstein
"Dave Alexander" wrote in
message news:EB634BDDE8FBD129DE851A1421086E07@in.WebX.maYIadrTaRb...
> Thanks Ken,
> Dave Alexander
> > (vl-load-com)
> > (vla-get-layers
> > '(lambda (x)
> > (vla-put-name
> > x
> > (vla-get-name x)))
> > (princ)
> > Ken Alexander
> > Acad2000
> > Windows2000 Prof.
> > --Albert Einstein
write
until...or
> > > Tim
Message 11 of 17
Ken,
I tried to modify the file to trim off the xref bind part of the layer
names, ie. 41261AWA$0$A-FLOR-CASE to A-FLOR-CASE and it doesn't do it.
Dave Alexander
news:B940FA09B3C9AF8D4DB8548D9B005768@in.WebX.maYIadrTaRb...
> You're Welcome.
> Ken Alexander
> Acad2000
> Windows2000 Prof.
> --Albert Einstein
Message 12 of 17
well, how'd you modify it?
the routine stripped chars from end of string, not beginning.
does this work?
(defun C:temp-lay_trim ()
(vl-load-com)
(vla-get-layers
'(lambda (x)
(vla-put-name
x
(vl-string-left-trim
"41261AWA$0$";;;characters to trim (case sensitive)
(vla-get-name x)))
(princ)
"Dave Alexander" wrote in message
news:6E8DCD895F2393A64E135B790D4CFD79@in.WebX.maYIadrTaRb...
> Ken,
> Dave Alexander
> > You're Welcome.
> > Ken Alexander
> > Acad2000
> > Windows2000 Prof.
> > --Albert Einstein
Message 13 of 17
Dave,
Notice in Mark's post, he replaced vl-string-right-trim with
vl-string-left-trim. You could have also used vl-string-trim, this
will remove the specified characters from the beginning and/or end.
Ken Alexander
Acad2000
Windows2000 Prof.
--Albert Einstein
message news:6E8DCD895F2393A64E135B790D4CFD79@in.WebX.maYIadrTaRb...
> Ken,
layer
it.
> Dave Alexander
> > You're Welcome.
> > Ken Alexander
> > Acad2000
> > Windows2000 Prof.
> > --Albert Einstein
Message 14 of 17
Thanks Ken, and Mark,
But it doesn't work. I am not being critical. My lisp is usually based on
someone elses work and I then modify it to suit my particualiar needs with
suitable credit to the original source (now that I am saving the original
source).
I think the problem is with the wildcard characters as I did originally
change it to vl-string-left-trim using *$0$ which didn't work.
I will try the vl-string-trim and see how that works.
Thanks again.
Dave Alexander
news:8DBD317AED1A516414F97835A21FB054@in.WebX.maYIadrTaRb...
> Dave,
> Ken Alexander
> Acad2000
> Windows2000 Prof.
> --Albert Einstein
> > Ken,
> layer
> it.
> > Dave Alexander
> > > You're Welcome.
> > > Ken Alexander
> > > Acad2000
> > > Windows2000 Prof.
> > > --Albert Einstein
Message 15 of 17
He is one way of searching for a pattern and trimming
it and all characters to the left.
;;;Looks for pattern and
;;;trims left side of string
;;;of the pattern and characters
;;;to the left of pattern.
(defun C:lay_trim (/ str searchstr)
(vl-load-com)
(vla-get-layers
'(lambda (x)
(setq str (vla-get-name x)
searchstr "$0$");;;set your pattern here
(if (vl-string-search searchstr str)
(vla-put-name x
(substr str
1
(+ (strlen searchstr)
(vl-string-search searchstr str))
str
(princ)
Ken Alexander
Acad2000
Windows2000 Prof.
--Albert Einstein
message news:EFC3AD8B6BEDB043AE216464ABFFFE0F@in.WebX.maYIadrTaRb...
based on
needs with
original
> source).
originally
> Thanks again.
> Dave Alexander
> > Dave,
this
end.
> > Ken Alexander
> > Acad2000
> > Windows2000 Prof.
> > --Albert Einstein
> > message
> > > Ken,
> > layer
do
> > it.
> > > Dave Alexander
> > > > You're Welcome.
> > > > Ken Alexander
> > > > Acad2000
> > > > Windows2000 Prof.
> > > > --Albert Einstein
Message 16 of 17
You guys & gals are simply AWESOME. You have made my job soooooooooooooooo much easier. I have taken your suggestions on code along with my own scribblings and added them to one master lisp routine. The old way of doing things normally took anywhere from 10 - 15 minutes per drawing and now with this master lisp routine, it takes less than 5 seconds. I have been working on updating literally hundreds of drawings. Last count I believe it was over 700 drawings. No kidding. Now, with this routine. I can clean these drawings up and save myself not only an extremely large amount of time, but thousands upon thousands of key strokes. It is just plain awesome. FANTASTIC. This is the way Autocad is meant to be done. Again, THANK YOU ALL!! You guys and gals are simply AWESOME.
"Catch" Ya Later,
Tim
Message 17 of 17
That is just too slick! Thanks for this fabulous .lsp routine!!! A wonderful "clean-up" tool.
K.
AutoCAD Inside the Factory
