Streamlined Linework Copying in Xref Drawings: Automatic 2-Unit Offset Automation
oscar.canedo.romero
oscar.canedo.romero
Is there a way to streamline the process of copying linework within an xref drawing by automatically incorporating both the "ncopy" and "offset" commands with a fixed distance of 2 units, eliminating the need to execute them separately each time?
RobDraw
Yeah, but I'm wondering, "Why?"
Rob
oscar.canedo.romero
Hi Rob, the purpose is to enhance efficiency and minimize time consumption when working on my drawing projects.
RobDraw
Yeah, you said that but what are you actually doing and why are you utilizing an XREF?
Rob
Kent1Cooper
Something along these lines [in most basic terms, very lightly tested]?
(defun C:NCO2 (); = Nested-Copy and Offset 2 drawing units
  (command
    "_.ncopy" (getpoint "\nNested object to copy & offset: ") "" "0,0" ""
    "_.offset" 2 (list (entlast) (getvar 'lastpoint)) pause ""
  ); command
  (prin1)
It honors your setting for the Erase option in the Offset command, but could be made to delete the Ncopied object regardless, if that's part of what you want to do.
It's a little odd about using (getpoint) for the selection [including running Osnap if it's on], because for some reason using (car (nentsel)) [the object part of nested-object selection] doesn't work in NCOPY, as I fully expected it to -- it says "No valid objects selected for NCOPY."  The result from (getpoint) is accepted, and finds the nested object.  That could probably be accounted for in some other way.
It doesn't do some things that it could be made to, such as to verify that the nested object you selected is Offsettable.
Kent Cooper, AIA
oscar.canedo.romero
Thank you very much. I'm extremely  grateful for your assistance and for taking the time to help.
This is perfect 😀
