Strange behavior thawning layers with entmod.
Hello everybody,
In some of my functions evolving layouts I had to create a way of freezing all layers so  AutoCad runned more smoothly.
The following two functions i use in the beginning and ending of other routines so they run faster but I'm having a very strange behavior:
(defun freezeall ()
  (setq cLay(tblnext "LAYER" T))
  (setq listagemparavoltar nil)
  (while cLay
    (if (= (cdr(assoc 2 cLay)) (getvar "CLAYER")) ;;;Is cLay Current Layer?;;;;
      (setq cLay(tblnext "LAYER")) ;;;If true;;;;
      (progn  ;;;If false start;;;;
	(SETQ listagemparavoltar
          (cons
            (list
              (assoc 2 cLay)
              (assoc 70
                (entget (tblobjname "LAYER" (cdr(assoc 2 cLay))))))
          listagemparavoltar))
	(entmod
	  (SUBST
	    (CONS 70 1)
	    (assoc 70 (entget (tblobjname "LAYER" (cdr(assoc 2 cLay)))))
      ) ;;;If false end;;;;
    ) ;;;End If;;;;
  ) ;;;End while;;;;
(defun thawlayers ()
  (foreach n listagemparavoltar
    (if (= (type n) 'list)
      (entmod
	(SUBST
	  (Car (cdr n))
	  (assoc 70 (entget (tblobjname "LAYER" (cdr (car n)))))
 It happens that the layers remain occult and they only reappear if I do "regenall" (manually, I tried doing it on Lisp but doest seem to have efect) on every layout, including modelspace.
Tank you very much for your help.
Marcos.
dbroad
Aside from regenmode perhaps being off, I don't see anything that would give you problems.  (Disclaimer:  Didn't look too closely).  How does your code work effectively different from this though?  Seems like a lot of work to avoid a command call.
(defun freezeall (/ *error*)
 ;null error routine
  (command "._-layer" "_freeze" "*" "")
(defun thawlayers (/ *error*)
 ;null error routine
  (command "._-layer" "_thaw" "*" "")
Architect, Registered NC, VA, SC, & GA.
Thanks Professor for your quick reply,
I find "entmod" a better way of dealing with properties changing because it:
1) Will work with undo;
2) Wont fill the command history with lots of Layer commands;
3) Also (in my opinion) it runs quicker if you are working with big dwgs.
Anyways I'll try using (command "._-layer") inside foreach to see what happens.
Marcos.
I've changed the Thawlayers function:
(defun thawlayers()
      (progn
	(if (= (cdr (car (cdr n))) 0)
	  (command "._-layer" "_thaw" (cdr (car n)) ""))))
Now it is working without having to Regenall.
P.S. I use the list "listagemparavoltar" because I want this function to thaw only the layers that were already thawed before the "Freezeall" function.
Marcos.
_Tharwat
A bit modification on your codes if you would like to:
    (if (and (= (type n) 'list)
(command "._-layer" "_thaw" (cdr (car n)) "")) )
@Anonymous wrote:
(defun thawlayers()
      (progn
dbroad
Glad to help and glad you got your fix.  Be sure to mark your modification as a solution if it fits your needs.
