Need this LISP to allow for selection of multiple objects
Message 1 of 11
I am trying to modify the attached LISP routine so I can manually select objects with a window instead of picking individual objects.  I cannot for the life of me get it right.  I am trying to use the following guidance I read online:
(setq sel1 (ssget "x"))
"This function allows you to select as many entities as you like using any selection method, such as Window, Crossing, Fence, etc.
You can also include a selection set filter within the function."
 I cannot make it work.  What am I doing wrong?
Replies (10)
Message 2 of 11
Sorrry Sorry Sorry!!! I forgot the LISP was supposed to be used OUTSIDE on the actual block and NOT inside the block editor!  I had what I wanted and didn't realize it!!  Learn from my mistakes!
Message 3 of 11
Satoews
try ssget without the x
(ssget)
Shawn T
Message 4 of 11
You are right about the ssget with nothing afterward....but I am constantly getting  bad argument type: consp errors.  Plus, my selection set is the whole block, not the individual objects, so clearly I am trying to put a square peg in a round hole...
Message 5 of 11
hmsilva
Hi neeboy,
are you trying to run your code only in block editor?
Henrique
Message 6 of 11
I need the code to run outside of the block editor.  I have to edit sometimes as many as several dozen, unique block definitions, and I'm looking to save time anywhere I can...hence trying to do away with constantly opening/closing the block editor every time.
Message 7 of 11
hmsilva
Ok!
And your goal is to select an INSERT and change all objects inside block definition to layer HILMOT-ARROWS, correct?
Henrique
Message 8 of 11
No. not ALL the objects, just the ones I select...and when I say select, I mean select with the normal "drag a window across" method.  I'm trying to avoid picking each individual object, some of them are lines less than an inch long and that gets a little unnerving, trying to pick 20-30 reaaaaally small lines individually.
I've got the "move-all" option already covered.
Message 9 of 11
hmsilva
We can't use nentsel with a selection window, therefore you'll probably have to open block editor and select the objects...
You can do all this in a code, but the selection have to be in block editor...
Henrique
Message 10 of 11
Yeah that's what I was afraid of...I'm concurrently working on ways to select EVERYTHING through LISP and put different things on different layers automatically (which I'm sure you've seen me post about).  That is proceeding along fine, but I'm trying to plan also for the times where I might ultimately not be able to grab everything with LISP.
Message 11 of 11
hmsilva
This one?
'trying to pick 20-30 reaaaaally small lines'
If the lines are realy small, and if there are no more small lines, test the 'Length' propertie with some fuzz and change those lines to layer HILMOT-ARROWS...
Hope this helps,
Henrique
