Visual LISP, AutoLISP and General Customization
Stop revcloud from inverting
5 REPLIES 5
sdvannelli
235 Views, 5 Replies
sdvannelli
Does anyone have a lisp routine, or just something that can be added to, the freehand revision cloud that prevents it from ever inverting itself at the last minute?
5 REPLIES 5
pendean
in reply to: sdvannelli
pendean
Community Legend
Community Legend
Draw a closed PLINE around it all then use the "object" sub-option in REVCLOUD to convert it has always been our office's favorite method.
HTH
HTH
devitg
in reply to: pendean
devitg
@pendean , As I understood ,  @sdvannelli  want to avoid the last option for REVCLOUD
pendean
in reply to: devitg
pendean
Community Legend
Community Legend
@devitg N (for no) is the default, requires not extra attention, and draws "clouds" (requested) but not "bursts" (the reverse of a cloud): and any custom LISP (I see the post got moved here now) would just respond with N anyway by default too. Yes?
devitg
devitg
@pendean Seem to be a good way , so a enter will not reverse.
calderg1000
calderg1000
Regards @sdvannelli
Maybe this code will help, previously you must configure the length of the arc according to your requirement.
(defun c:rv()
(vl-cmdf "revcloud" "o" pause "")
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Regards @sdvannelli
(defun c:rv()
Carlos Calderon G
AutoCAD Inside the Factory
