Still looking for a shutting down reactor....
Message 1 of 13
Hi Gang,
I'm hoping somebody has found one now.....
I've got document reactors running that sense a jump between drawings.
(MDI). What I'm looking for is a way to STOP those reactors when a user
does something that causes the system to exit AutoCAD. A good one is when
the user hits the "X" to close down AutoCAD.
(My document reactors tell the user when they switch to a "RAW" drawing
versus a drawing that has been configured with project number and such. We
want to alert the user to this fact. Right now, you shut down Acad. The
system will continue to display the warnings until all documents have been
shut down.)
Anybody have any ideas?
Nick
Env: A2K/VC6/W2K
Replies (12)
Message 2 of 13
How about this? In the CommandWillStart reactor, if the command us "QUIT",
you call (vl-bb-set 'ShutDown T). In your document reactor, you call
(vl-bb-ref 'ShutDown) in an if statment to decide whether to excecute the
rest of your code. If need be, you can place a balancing call to (vl-bb-ref)
in the commandCancelled reactor in case the user decides to cancel the
shutdown. Then your drawing reactors will still function the way you
designed them.
"Nick Jacobs" wrote in message
news:[email protected]...
> Hi Gang,
We
> shut down.)
> Thanks,
> Nick
> Env: A2K/VC6/W2K
Message 3 of 13
Humm.... I wonder if the "X" fires a "QUIT" or if it tells the application
to do something else.... I'll look into that....
In any case, thanks for responding!!!!!!!!
Nick
"Frank Oquendo" wrote in message
(vl-bb-ref)
> designed them.
> > Hi Gang,
when
> We
been
> > shut down.)
> > Thanks,
> > Nick
> > Env: A2K/VC6/W2K
Message 4 of 13
What's not to respond? If I'm wrong, it was free in the first place. If I'm
right, I come up nice and shiny! 😃
> Nick
"QUIT",
the
> (vl-bb-ref)
> > designed them.
> > > Hi Gang,
user
> when
drawing
such.
> > We
The
> been
> > > shut down.)
> > > Thanks,
> > > Nick
> > > Env: A2K/VC6/W2K
Message 5 of 13
Nick - Use VLR-DocManager-Reactor to detect opening/closing.
Nick Jacobs wrote:
> Hi Gang,
> shut down.)
> Thanks,
> Nick
> Env: A2K/VC6/W2K
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* [email protected] */
/* http://ourworld.compuserve.com/homepages/tonyt */
Message 6 of 13
Tony,
I'm already using that reactor to sense when I'm switching to and from the
documents. Actually, I had it set to DocumentBecameActive (or current or
which ever.) The problem is, when you do a shutdown of acad, all of the
documents become current for at least blip or so. Acad checks to see if the
document needs saved which fires the reactors.... yadayadayada.... It's
even more strange because if you put dialogs in your reactors (ala don't do
that kinda dialogs) then they'll show up AFTER the acadframe has shut
down... Kinda goofy...
Nick
"Tony Tanzillo" wrote in message
> Nick Jacobs wrote:
> > Hi Gang,
when
We
been
> > shut down.)
> > Thanks,
> > Nick
> > Env: A2K/VC6/W2K
Message 7 of 13
And I appreciate it.
> Hehehe, thanks Frank.
> I just like to say thanks where thanks is due. 🙂
> Sometimes people don't appreciate the contributions around this net
> thingy...... I just like to let people know that I do. Been that way since
> way back in the Compuserve days...
Message 8 of 13
Nick
I'm
application
> > Nick
> "QUIT",
> the
> > (vl-bb-ref)
> > > designed them.
> > > > Hi Gang,
drawings.
> user
is
> > when
> drawing
> such.
> > > We
> The
have
> > been
> > > > shut down.)
> > > > Thanks,
> > > > Nick
> > > > Env: A2K/VC6/W2K
Message 9 of 13
I take it you're removing your reactor from
AcRx::kUnloadAppMsg/UnloadApplication().
Try handling AcDbEditorReactor::beginQuit() to see if it gets called
before the documentBecameCurrent(). If so, couldn't you set a global
variable and check that before starting your dialog...
Nick Jacobs wrote:
> Tony,
| Byron Blattel
| CADwerx---Applications for AutoCAD
| e-mail: [email protected]
Message 10 of 13
Byron,
That's essentially what I'm trying to code right now.
I'm going to start out doing it with vl-reactors and then move it into an
arx file *hopefully* that is.
In any case,
Thanks for replying!!!!
Nick
"Byron Blattel" wrote in message
> Nick Jacobs wrote:
> > Tony,
the
or
the
do
> | Byron Blattel
Message 11 of 13
Nick - Unfortunately Autodesk has left numerous defects in its APIs.
For example, the AcApDocManagerReactor is broken in several
regards. Here's what I have found:
1. The documentActivated() member does not fire when a
document is made active via the ActiveX API.
2. The documentToBeDestroyed() member never fires at all.
3. The documentActivationModifed() member does not fire
when it should, and sometimes fires when its shouldn't.
With defects like this, it's difficult to do anything without
being forced to using all sorts of insidious kludges.
Nick Jacobs wrote:
> Tony,
> Nick
> > Nick Jacobs wrote:
> > > Hi Gang,
> when
> We
> been
> > > shut down.)
> > > Thanks,
> > > Nick
> > > Env: A2K/VC6/W2K
Message 12 of 13
Tony,
Amen to that....... I've found some like that plus one or two when running
with W2K that make this interesting....
Nick
> Nick Jacobs wrote:
> > Tony,
the
or
the
do
> > Nick
> > > Nick Jacobs wrote:
> > > > Hi Gang,
drawings.
user
is
> > when
drawing
such.
> > We
The
have
> > been
> > > > shut down.)
> > > > Thanks,
> > > > Nick
> > > > Env: A2K/VC6/W2K
Message 13 of 13
Well Frank,
What you suggested works great for all normal messages.... What it doesn't
work with is the "X" way of shutting down AutoCAD (Close Type messages from
the system).....
Getting there..
Have you ever worked with the WinHook functions? I was looking at them as a
way to get the Quit Message and the turning off reactors...
What do ya think?
Nick
since
