Startup Lisp with Folder Paths?
MSchille-1994
MSchille-1994
I have a startup lisp (shown in the screenshot below) that runs each time AutoCAD/Civil 3D is run.  In that lisp file are three different sections.  The first one loads custom lisp routines.  The second one sets various system variables.  The third one runs a couple of commands.
I'd like to add a fourth section that includes adding a couple of Support File search paths, a Trusted Folder search path, and a Printer Support search path.  All of these folders reside on our office server.
How do I go about adding into my startup lisp, a routine that appends the current folder listings by adding in some custom paths that I want?  For example, in the very first section of the folder paths, Support Folders, I want to add in our m:\ drive.  In the Trusted Folders section I'd like to add in our u:\ drive.  In the Plotter Support Search path I'd like to add in our m:\ drive.
I have seen several posts on this idea but they all vary so much so I am not sure where to start and my lisp routine writing ability is pretty limited.
Thanks for any help.
Michael
Attitude, not Aptitude, Determines Altitude
alanjt_
Paste the following line of code into the command line and it should give you access to all the pathing changes you want to make.
(vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-acad-object))) T)
Sea-Haven
You want something like this but you should check is path already exist.
(setq *files*  (vla-get-files  (vla-get-preferences (vlax-get-Acad-object))))
(setq paths (vla-get-SupportPath *files*))
(setq XXXXpaths "L:\\autodesk\\supportfiles;L:\\autodesk\\lisp;L:\\autodesk\\fonts;")
(setq newpath (strcat XXXXpaths paths))
(vla-put-SupportPath *files* newpath)
(setq oldtrust (getvar 'trustedpaths))
(setq newtrust (strcat oldtrust ";" "L:\\Autodesk..."))
(setvar 'trustedpaths newtrust)
martti.halminen
We do this in a different way: we use our own profile, which has all the path definitions we need, and define the the profile to use in the shortcut used to start AutoCAD.
- This approach requires that the paths are rather static. If you need different paths depending on which customer or which project you are working on, the programmatic approach would be better.
MSchille-1994
Okay @Sea-Haven , so I put that into my lisp file and it works the first time I run cad.  Problem is, the next time I run cad, it adds those paths in again, so I end up with multiple instances of my folder paths.  This kind of makes sense as the second time I run cad, it IS getting the search paths, which already contain the folders I want, so it adds them in but then puts back the previous set of search paths, which already contained the extra folders I want.  See below.......
alanjt_
Read the existing paths and use wcmatch to see if they already exist. If so, skip and onto the next.
MSchille-1994
Sorry @alanjt_ , I am very novice to Lisp and trying to make this work.  What do you mean to use "WCMATCH"?
