Modify Endpoint Help
Jonathan3891
Advisor Advisor
Message 1 of 14
Jonathan3891
Unfortunately I don't have anything started to critique. I cant seem to find anything that is similar to what I'm trying to accomplish. So I'm turning to the experts here to point me in the right direction.
The easiest way to describe what I'm tying to do is break it down into workflow:
Select Object(s)
Pick endpoint to modify
Enter Distance
Move object(s) endpoint in the z axis only by the distance entered
Jonathan Norton
Blog | Linkedin
Replies (13)
Message 2 of 14
marko_ribar
Is this for 3DPOLYLINE?
If so, you have to collect all vertices via (entnext) or (vla-get-coordinates) and then entmod that VERTEX coordinate (assoc 10), finally you refresh main parent entity (entupd (cdr (assoc -1 (entmod 3dpolyDXFdata))))...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 14
hak_vz
@Jonathan3891Is this what you are looking for?
Function changes picked point of line or 3dpolyline for some delta Z.
(defun c:changeEndpointZ ( / e eo del coords np sp ep vlapt)
(defun take (amount lst / ret) (repeat amount (setq ret (cons (car lst) (take (1- amount) (cdr lst))))))
	(cond
		((and(setq e (car (entsel "\nSelect linea type object <LINE | 3DPOLYLINE>"))))
			(setq eo (vlax-ename->vla-object e))
			(cond
				((or(= (vlax-get eo 'ObjectName)"AcDbLine")(= (vlax-get eo 'ObjectName)"AcDb3dPolyline"))
					(setq pt (getpoint "\nSelect endpoint to change Z coordinate > "))
					(setq del (getdist "\nInput endpoint delta Z >"))
					(cond
						((and del (= (vlax-get eo 'ObjectName) "AcDbLine"))
							(if (= (apply '+  (mapcar '- pt (vlax-get eo 'Endpoint))) 0)
								(vlax-put eo 'Endpoint (mapcar '+ (vlax-get eo 'Endpoint) (list 0 0 del)))
								(vlax-put eo 'StartPoint (mapcar '+ (vlax-get eo 'StartPoint) (list 0 0 del)))
						((and del (= (vlax-get eo 'ObjectName) "AcDb3dPolyline"))
							(setq
								coords (vlax-get eo 'Coordinates) np (/ (length coords) 3)
								ep (reverse(take 3 (reverse coords)))
								sp (take 3 coords)
								vlapt (vlax-make-safearray vlax-vbdouble '(0 . 2))
							(if (= (apply '+ (mapcar '- pt ep)) 0)
								(progn (vlax-safearray-fill vlapt (mapcar '+ ep (list 0 0 del))) (vla-put-coordinate eo (- np 1) vlapt))
								(progn (vlax-safearray-fill vlapt (mapcar '+ sp (list 0 0 del))) (vla-put-coordinate eo 0 vlapt))
				(T (princ "\nSelected object is not a line or 3dpolyline entity!"))
(princ)
Miljenko Hatlak
Message 4 of 14
Jonathan3891
Its actually a Advance Steel element.
Jonathan Norton
Blog | Linkedin
Message 5 of 14
hak_vz
I don't use Advance Steel so ad to your next post dumped properties of desired elements?
(vlax-dump-object (vlax-ename->vla-object (car(entsel "\nSelect object"))))
Next time please be more specific with your request, this is not your first request to this forum and you probably know how things work.
Miljenko Hatlak
Message 6 of 14
devitg
@Jonathan3891 For better understanding, and maybe get further help, please upload such sample.dwg
Message 7 of 14
Kent1Cooper
Select Object(s)
Enter Distance
If you're picking the object, picking the point, and entering the distance, you don't need a routine which won't really save you any steps.  Just pick the object, pick the grip at the point in question, and type in @0,0,YourZaxisDistance, and it will move there if eligible to [e.g. not a LWPolyline vertex because you can't take a vertex out of the plane of the rest of it, but it will work on a Line, a 3DPolyline, a Circle center, Text insertion point, etc.].  The distance can be positive or negative.  You'll need to have Osnap off if any running mode(s) would "see" the original location of the point and snap back to it.
Kent Cooper, AIA
Message 8 of 14
Jonathan3891
Select Object(s)
Enter Distance
@Kent1Cooper That's how I've been doing it. Just wanted to see if it was something that could be done via lisp.
Is it possible to pick near the side that's to be adjusted, similar to your toggle dim extension lisp?
Jonathan Norton
Blog | Linkedin
Message 9 of 14
Jonathan3891
Select object; IAcadEntity: AutoCAD Entity Interface
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff6b8e22ec0>
;   Document (RO) = #<VLA-OBJECT IAcadDocument 000002bfe0d3ba98>
;   EntityTransparency = "ByLayer"
;   Handle (RO) = "356"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000002bfe105adb8>
;   Layer = "Vertical Bracing"
;   Linetype = "ByLayer"
;   LinetypeScale = 20.0
;   Lineweight = -1
;   Material = "ByLayer"
;   ObjectID (RO) = 46
;   ObjectName (RO) = "AstBeamRepr"
;   OwnerID (RO) = 47
;   PlotStyleName = "ByLayer"
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 000002bfe105c010>
;   Visible = -1
T
Jonathan Norton
Blog | Linkedin
Message 10 of 14
Kent1Cooper
So that list of VLA properties doesn't seem to include anything about points that could have new values assigned to them.  What is its entity data list like?  That is, what does this return?
(entget (car (entsel "\nSelect object: ")))
Or, another kind of list of properties, in case it reveals anything a routine could work with:
(dumpallproperties (car (entsel "\nSelect object: ")))
Kent Cooper, AIA
Message 11 of 14
Jonathan3891
@Kent1Cooper wrote:
So that list of properties doesn't seem to include anything about points that could have new values assigned to them.  What is its entity data list like?  That is, what does this return?
Here it is
Select object: ((-1 . <Entity name: 2bfe18ca5e0>) (0 . "ASTBEAM") (330 . <Entity name: 2bfe18c61f0>) (5 . "356") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "Vertical Bracing") (48 . 20.0))
Jonathan Norton
Blog | Linkedin
Message 12 of 14
Jonathan3891
Select object: Begin dumping object (class: AstBeamRepr)
Annotative (type: bool)  (LocalName: Annotative) = Failed to get value
AnnotativeScale (type: AcString)  (RO)  (LocalName: Annotative scale) = Failed to get value
Approval comment (type: AcString)  (RO) = -
Approval status (type: AcString)  (RO) = Not Set
Approval status code (type: AcString)  (RO) = -
Assembly mark (type: AcString)  (RO) = -
BlockId (type: AcDbObjectId)  (RO) = 2bfe18c61f0
Carrier (type: AcString)  (RO) = -
CastShadows (type: bool) = 1
ClassName (type: AcString)  (RO) =
Coating (type: AcString)  (RO) = None
CollisionType (type: AcDb::CollisionType)  (RO) = 1
Color (type: AcCmColor)  (LocalName: Color) = BYLAYER
Commodity number (type: AcString)  (RO) = -
Confidence (type: AcString)  (RO) = None
Construction class (type: AcString)  (RO) = None
Delivery date (type: AcString)  (RO) = -
Detail class (type: AcString)  (RO) = None
Exact weight (type: AcString)  (RO) = 46.92
ExtensionDictionary (type: AcDbObjectId)  (RO) = 0
Fabrication station (type: AcString)  (RO) = -
Free remark (type: AcString)  (RO) = -
Handle (type: AcDbHandle)  (RO) = 356
HasFields (type: bool)  (RO) = 0
HasSaveVersionOverride (type: bool) = 0
Heat number (type: AcString)  (RO) = -
Hyperlinks (type: AcDbHyperlink*)
IsA (type: AcRxClass*)  (RO) = AstBeamRepr
IsAProxy (type: bool)  (RO) = 0
IsCancelling (type: bool)  (RO) = 0
IsEraseStatusToggled (type: bool)  (RO) = 0
IsErased (type: bool)  (RO) = 0
IsModified (type: bool)  (RO) = 0
IsModifiedGraphics (type: bool)  (RO) = 0
IsModifiedXData (type: bool)  (RO) = 0
IsNewObject (type: bool)  (RO) = 0
IsNotifyEnabled (type: bool)  (RO) = 0
IsNotifying (type: bool)  (RO) = 0
IsObjectIdsInFlux (type: bool)  (RO) = 0
IsPersistent (type: bool)  (RO) = 1
IsPlanar (type: bool)  (RO) = 0
IsReadEnabled (type: bool)  (RO) = 1
IsReallyClosing (type: bool)  (RO) = 1
IsTransactionResident (type: bool)  (RO) = 0
IsUndoing (type: bool)  (RO) = 0
IsWriteEnabled (type: bool)  (RO) = 0
L section [%s]: (type: AcString)  (RO) = 2550.1
L system [%s]: (type: AcString)  (RO) = 2550.1
LayerId (type: AcDbObjectId)  (LocalName: Layer) = 2bfe18a4900
LineWeight (type: AcDb::LineWeight)  (LocalName: Lineweight) = -1
LinetypeId (type: AcDbObjectId)  (LocalName: Linetype) = 2bfe18c6150
LinetypeScale (type: double)  (LocalName: Linetype scale) = 20.000000
Load Number (type: AcString)  (RO) = -
LocalizedName (type: AcString)  (RO) =
Lot/Phase (type: AcString)  (RO) = -
Material (type: AcString)  (RO) = S355JR
MaterialId (type: AcDbObjectId)  (LocalName: Material) = 2bfe18c6640
MergeStyle (type: AcDb::DuplicateRecordCloning)  (RO) = 1
Model Role (type: AcString)  (RO) = None
Name (type: AcString)  (RO) = TN150x150x6.5x9
ObjectId (type: AcDbObjectId)  (RO) = 2bfe18ca5e0
OwnerId (type: AcDbObjectId)  (RO) = 2bfe18c61f0
PO number (type: AcString)  (RO) = -
PlotStyleName (type: AcString)  (RO)  (LocalName: Plot style) = ByColor
Pre defined remark (type: AcString)  (RO) = -
Preliminary mark (type: AcString)  (RO) = -
Profile (type: AcString)  (RO) = TN150x150
ReceiveShadows (type: bool) = 1
Requisition number (type: AcString)  (RO) = -
Section class (type: AcString)  (RO) = China T
ShadowDisplay (type: AcDb::ShadowFlags)  (LocalName: Shadow Display) = 0
Shipped date (type: AcString)  (RO) = -
Shrink (draw) (type: AcString)  (RO) = 0.0
Single part mark (type: AcString)  (RO) = -
Supplier (type: AcString)  (RO) = -
Transparency (type: AcCmTransparency)  (LocalName: Transparency) = 0
Type (type: AcString)  (RO) = Straight beam
User Attribute 01 (type: AcString)  (RO) = -
User Attribute 02 (type: AcString)  (RO) = -
User Attribute 03 (type: AcString)  (RO) = -
User Attribute 04 (type: AcString)  (RO) = -
User Attribute 05 (type: AcString)  (RO) = -
User Attribute 06 (type: AcString)  (RO) = -
User Attribute 07 (type: AcString)  (RO) = -
User Attribute 08 (type: AcString)  (RO) = -
User Attribute 09 (type: AcString)  (RO) = -
User Attribute 10 (type: AcString)  (RO) = -
Visible (type: AcDb::Visibility) = 0
Weight (type: AcString)  (RO) = 46.92
End object dump​
Jonathan Norton
Blog | Linkedin
Message 13 of 14
Kent1Cooper
Neither that entity data list nor the dumped properties appears to contain anything about points that could have new values assigned, so an AutoLisp routine, at least, may not be an option.  There's an Advance Steel Forum where you could ask.
Kent Cooper, AIA
Message 14 of 14
Jonathan3891
Thanks @Kent1Cooper !
Jonathan Norton
Blog | Linkedin
