STARTAPP: Software not starting completely
alexander.langenstein
Message 1 of 13
Hello.
I have created a custom ribbon with some custom functions...
And now i want to include an external software into the ribbon and start it from there.
I have created the function and at the moment it looks like this:
^C^C(startapp "C://Program Files//Itwh//KOSTRA-DWD 2020 4.2//KOSTRA-DWD-2020.exe")
The Software is starting, but after the loadingscreen nothing happens.
Has someone an idea what the problem is?
With other softwares i don't have the problem.
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
Adding LISP code to a button on the Ribbon is not going to change autocad's startup alone: may I ask where you read this would be an option or solution?
And what is "KOSTRA-DWD-2020.exe" please? What would it do once triggered?
Message 3 of 13
i have read it in a couple of forum threads.
i have tried it with my pdf-Software and there is no problem... it starts as it should.
"KOSTRA-DWD-2020.exe" is a software from the german weather service to get rain data.
I just want to start the software from my custom Ribbon in Autocad.
In this case i only get the loadingscreen.
Message 4 of 13
CodeDing
@alexander.langenstein ,
the (startapp ...) function can be difficult sometimes. I would recommend trying to add quotes surrounding the string of the application being called. Also, it appears you're using a forward slash when you should be using a backslash. I would update it like this:
^C^C(startapp "\"C:\\Program Files\\Itwh\\KOSTRA-DWD 2020 4.2\\KOSTRA-DWD-2020.exe\"")
Best,
~DD
Message 5 of 13
paullimapa
Try using a single / instead of double //. A double is only needed for this \\
Paul Li
IT Specialist
@The Office
Message 6 of 13
Hi.
This line is not working.
Message 7 of 13
This works the same as my code.
I also get the loadingscreen and after that nothing happens.
There seems to be a problem with this exact problem.
I also created a ticket for the autodesk support.
Message 8 of 13
paullimapa
Just out of curiosity does this run properly when you open Windows Explorer, locate the file and you double click on it?
C:\Program Files\Itwh\KOSTRA-DWD 2020 4.2\KOSTRA-DWD-2020.exe
Paul Li
IT Specialist
@The Office
Message 9 of 13
It works fine... no problem.
That's what surprises me.
Message 10 of 13
paullimapa
Are you running on Windows 10 or 11?
What version of AutoCAD?
Did you install latest AutoCAD updates?
Paul Li
IT Specialist
@The Office
Message 11 of 13
Sea-Haven
I counted 3 spaces so running a shell/startapp it can stop at the 1st space a DOS problem.
I would try ^C^C(startapp "C:\\Program Files\\Itwh\\KOSTRA-DWD 2020 4.2\\KOSTRA-DWD-2020.exe")
Message 12 of 13
CADaSchtroumpf
And with ActiveX? No tested, but for exemple...
(cond
	((setq folder (findfile "C:\\Program Files\\Itwh\\KOSTRA-DWD 2020 4.2\\KOSTRA-DWD-2020.exe"))
		(setq WshShell (vlax-create-object "WScript.Shell"))
		(vlax-invoke-method wshshell "Run" (strcat (substr folder 1 42) "KOSTRA-DWD-2020.exe") 1 :vlax-false)
		(vlax-release-object WshShell)
	(T (princ "\nFile \"KOSTRA-DWD-2020.exe\" not found") (prin1))
Message 13 of 13
I have talked to the Autodesk-Support.
It seems not to be a Autocad problem.
I have tried to launch the software with a batchfile and i got the same issue.
Now we found a solution also with a batchfile:
CD "C:\Program Files\Itwh\KOSTRA-DWD 2020 4.2"
KOSTRA-DWD-2020.exe
exit
And now i start the batchfile:
^C^C(startapp "C:/Kostra-4.2.bat")
