SSGET to select a polyline using two coordinates as filters
Message 1 of 21
Why the SSGET command line using StartPoint AND EndPoint variables/filters doesn't work?
(setq SelSet (ssget "_:L" '((0 . "*POLYLINE"))))
(setq na1 (ssname SelSet 0))
(setq obj (vlax-ename->vla-object na1))
(setq StartPoint (vlax-curve-getStartPoint obj) )
(setq EndPoint (vlax-curve-getEndPoint obj) )
(setq ss1 (ssget "C" StartPoint EndPoint '((0 . "*POLYLINE"))  (-4 . "=,=,*") (10 (car StartPoint) (car (cdr StartPoint)) 0.0 )))
StartPoint AND EndPoint vertices can be in any position/sequence, not necessary the first vertex coordinate.
The command still incomplete because I need to ADD EndPoint on the filters.
The goal is to complete the RED polyline with the vertices of the WHITE one (check image). It's the next step of the code.
Thanks in advance + regards,
lzucco
Accepted solutions (4)
Replies (20)
Message 21 of 21
best solution I found for solving
minimum distance between two objects
https://autocadtips1.com/2017/03/13/lisp-version-of-closest-distance-between-two-objects/
