link base points block like a swarm
jtm2020hyo
jtm2020hyo
...I mean something  like images below (lisp does not need be exactly as imagen) :
PD:  I leave a LISP routine that might be useful as a base.
ВeekeeCZ
Here is something to play with. Have fun.
(defun c:BConnenct (/ ss dst ang pts pt)
  (if (and (setq ss (ssget '((0 . "INSERT,CIRCLE,POINT"))))
	   (setq dst (getdist "\nMax distance: "))
	   (not (initget "Horizontal Vertical Orthogonal Diagonal Angular"))
	   (or (setq ang (getkword "\nExclude direction [Orthogonal/Horizontal/Vertical/Angular/Diagonal] <none>: "))
	       T)
	   (setq pts (mapcar '(lambda (e)
				(cdr (assoc 10 (entget e))))
			     (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
    (repeat (1- (length pts))
      (setq pt (car pts)
	    pts (cdr pts))
      (foreach px pts
	(and (<= (distance pt px) dst)
	     (cond ((not (setq ax (angle pt px))))
		   ((not ang))
		   ((= ang "Horizontal")
		    (not (equal (rem ax pi) 0. 1e-3)))
		   ((= ang "Vertical")
		    (not (equal (rem ax pi) (/ pi 2) 1e-3)))
		   ((= ang "Orthogonal")
		    (not (equal (rem ax (/ pi 2)) 0. 1e-3)))
		   ((= ang "Angular")
		   ((= ang "Diagonal")
		    (not (equal (rem ax (/ pi 2) (/ pi 4)) 0. 1e-3))))
	     (entmake (list (cons 0 "LINE")
			    (cons 10 pt)
			    (cons 11 px)))))))
  (princ)
Note. If the red ones are missing on purpose, you're unable to exclude them.
Edit: code updated.
jtm2020hyo
great advance.
I do not if I'm doing it right but the angular option does not work for me.
ВeekeeCZ
I'm afraid you must be misunderstood something. The routine works exactly as designed.
Anyway, if you need to do some adjustments, feel free to do that by yourself. The routine should offer you a lot to learn from. Have fun!
jtm2020hyo
thanks for your help.
