SSGET "X" formatting
dplumb_BWBR
Advisor Advisor
dplumb_BWBR
Can anyone tell me why this fails
_$ (setq PLineSS (ssget "x" '((-4 . "<AND") (0 . "LWPOLYLINE") (CONS 8 "AC*") (-4 . "AND>"))))
; error: bad SSGET list
and this works?
_$ (setq PLineSS (ssget "x" '((-4 . "<AND") (0 . "LWPOLYLINE") (8 . "AC*") (-4 . "AND>"))))
<Selection set: 2e>
If I do (CONS 8 "AC*") all by itself, it returns (8 . "AC*"), so it seems the same to me.
TIA
scot-65
When CONStructing a dotted pair, one cannot 'Quote.
One must use (LIST...
(LIST (-4 . "<AND") (0 . "LWPOLYLINE") (CONS 8 "AC*") (-4 . "AND>"))
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
cadffm
evaluate by the first step to
because you quote the list - Your apostroph after "x" mean that "do nothing inside the following argument/list
and (CONS 8 "AC*")  isn't a valid item for a filter list.
and (8 ". AC*")  is a valid item for a filter list.
 take a look:
(setq PLineSS (ssget "x" (list '(-4 . "<AND") '(0 . "LWPOLYLINE") (cons 8 "AC*") '(-4 . "AND>"))))
in this case not very useful, but this is how it works.
(defun SL (lay)
  (ssget "_X" (list '(-4 . "<AND") '(0 . "LWPOLYLINE") (cons 8 lay) '(-4 . "AND>"))))
Sebastian
Kent1Cooper
In addition to using the explicit (list) function instead of the (quote) [ ' ] function when there's something requiring evaluation in the list, in this case you don't need the (cons) function [and therefore don't even need the explicit (list) function], and  you don't need the <AND> wrapping.  You should be able to do just this:
(setq PLineSS (ssget "_X" '((0 . "LWPOLYLINE") (8 . "AC*"))))
Kent Cooper, AIA
Kent1Cooper
@Kent1Cooper wrote:
....  You should be able to do just this:
Now, if [for example] the "AC" part of the beginning of Layer names was something that would vary  in different usage, and was stored in a variable  established by asking the User, or by picking on an object on a Layer whose name starts with the letter combination you're after and extracting that Layer name start, then  you would need to do some evaluating/operations to combine that Layer-name beginning with an asterisk to catch all following Layer name content, and to "consociate" that string with an 8 to apply it for Layer names, and therefore you would need the (cons) and the explicit (list) function, like this [with LayerNameStart being the variable name]:
(setq PLineSS (ssget "_X" (list (0 . "LWPOLYLINE") (cons 8 (strcat LayerNameStart "*")))))
Kent Cooper, AIA
dplumb_BWBR
Thanks! That did the trick.
It's been a while since I did any serious LISPing.
I've forgotten some of the intricacies.
