point coordinates command
hallo,
I would like to check for point coordinates with a command alias on the command bar.
which command should I apply for?
I was thinking about something like "identity point".. but I found nothing like that
thanks
ВeekeeCZ
There is a build-in command called ID. Isn't it what you want?
Hi
You can also use the List command for getting the coordinates of an object. it may be a point also.
