ssget "_P" and then continue to select more with filter or remove from selection
paullimapa
Mentor Mentor
Message 1 of 11
paullimapa
Is there a way to do ssget "_P" and then continue to allow the option to select more adding to selection total set or remove objects from previous selection set with filter list?
Paul Li
IT Specialist
@The Office
Replies (10)
Message 2 of 11
ВeekeeCZ
Try to search, it was here a few times before.
Just what pops out of my mind...
(initcommandversion) (command-s "_.select" "_p")
Message 3 of 11
paullimapa
Thanks for your quick reply. I'm aware of the Select command. What I'm trying to do is include in the ssget function the previous selection set with filters and continue to either select more or/and remove objects ie: (setq ss1 (ssget "P" ' ( (0 . "LINE")))).  This unfortunately, just creates a selection set filtering out LINE objects from the previous set but does not allow me to continue to select more LINE objects or deselect (remove) objects from the now highlited "P" set.
Paul Li
IT Specialist
@The Office
Message 4 of 11
ВeekeeCZ
Just to clarify, my suggestion does allow you to add/remove objects from the highlighted previous selection.
It does not allow to apply a filter on them.
Message 5 of 11
paullimapa
Yes, filtering is what's missing from your answer. Thanks again.
Paul Li
IT Specialist
@The Office
Message 6 of 11
hmsilva
Something like this, perhaps
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "_P\r")
(setq ss1 (ssget '((0 . "Line"))))
Hope this helps,
Henrique
Message 7 of 11
paullimapa
@hmsilva Thank you so much...this is exactly what I was looking for...works beautifully!!!!
Paul Li
IT Specialist
@The Office
Message 8 of 11
hmsilva
You're welcome, Paul
Glad I could help
Henrique
Message 9 of 11
devitg
@hmsilva Henrique , would you please , explain about the
as I can see it send , both the Previous and remove .
what others applications ?
Message 10 of 11
hmsilva
Hi Gabriel,
it sends the _P to the command line, the \r is a carriage return (enter)...
Henrique
Message 11 of 11
ВeekeeCZ
Nice trick Henrique!
I probably never realized that classic hidden selection options are still available under (ssget).
Command: (ssget)
Select objects: ?
*Invalid selection*
Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle
 This the the P that (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "_P\r") selects!
