Add ordinate dimension to linear dimension automatically
accounts
accounts
Hi All,
I am searching for a lisp that can do things as below:
1. set origin for linear and ordinate
2. continuously dimension the points I want with linear and ordinate dimension at same time.
the result I want to achieve would be like this:
Thanks in advance
accounts
ADDITIONAL
If the ordinate dimension can be added without jog that will be great.
ВeekeeCZ
Like this using QDIM?
(defun c:QD ( / s)
  (if (setq s (ssget))
    (command-s "_.qdim" s "" "_p" pause "_o"))
  (princ)
accounts
the result is similar, but not the same. I want to continuously dimension things point by point, not by selected geometry.
