SSGET PROBLEM
SSGET PROBLEM
Message 1 of 15
SSGET PROBLEM
I would be very appreciative if someone could help me with what I think is
a simple problem. I want to use the SSGET command to select all objects of
a particular name that are inside a window that I select. I know how to
select all objects in the drawing of the correct name but I'm not sure how
to make it work with a window. Do the window coordinates need to be
obtained before the SSGET and then included in the SSGET command or can
they be obtained within the SSGET.
Thanks for any help!
Chris E
Replies (14)
Message 2 of 15
You can do this by just eliminating the "x" paramter
from (ssget):
Instead of (ssget "x" '((..filter..)))
Just use (ssget '((.... filter ....)))
> Chris E
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* [email protected] */
/* http://ourworld.compuserve.com/homepages/tonyt */
Message 3 of 15
Chris,
To obtain the objects using the normal windowing method (along with any
other method) you might use something like:
(defun c:ssgetw ()
(setq ss (ssget '((0 . "LINE"))))
(command "erase" ss "")
(princ)
To obtain the objects using a specified window only, you might use
something like:
(defun c:ssgetwa ()
(setq p1 (getpoint "\nFirst corner of window: "))
(setq p2 (getcorner p1 "\nOther corner of window: "))
(setq ss (ssget "W" p1 p2 '((0 . "LINE"))))
(princ)
Hope this gives you some ideas.
FD
chris emmerick wrote in article
<01bf6d52$f4301180$9dd66ccb@chris>...
is
of
how
> Chris E
Message 4 of 15
I suggest you use just plain (ssget) and then filter the reguiered
objects from it.
This way you are free to select anything or way you want.
Good luck
Marcel Janmaat
-----Oorspronkelijk bericht-----
Van: chris emmerick [mailto:[email protected]]
Gepost op: woensdag 2 februari 2000 9:56
Gepost naar: customization
Discussie: SSGET PROBLEM
Onderwerp: SSGET PROBLEM
is
of
how
Chris E
Message 5 of 15
And how would you recommend doing that? Filters are applied to selections
not selection sets. The suggestions offered by Tony and Flitter are correct.
"Marcel Janmaat" wrote in message
news:048CF107BE98D211A6440008C7456EA30F2ACE@HE-MAILSRV...
> objects from it.
> Good luck
> Marcel Janmaat
> is
> of
> how
> Chris E
Message 6 of 15
Frank,
Some programmers do select all objects, filter each object in the selection
set, and then remove any that do not match the criteria from the selection
set with ssdel.
Reminds me of putting all of the chickens in the pen, then killing the hens
just to get the roosters. 🙂
Dave D
Frank Oquendo wrote in article
<[email protected]>...
correct.
> > objects from it.
> > Good luck
> > Marcel Janmaat
> > is
> > of
to
> > how
> > Chris E
Message 7 of 15
I can't imagine why anyone would want to do an entget and check the 0 fields
of every entity when they could just use a selection set filter. Guess I'm a
little myopic.
"David Doane" wrote in message
news:01bf6db1$51518840$8355d2d0@lms-1...
> Frank,
selection
> set with ssdel.
hens
> Dave D
selections
> correct.
> > > objects from it.
> > > Good luck
> > > Marcel Janmaat
think
> > > is
objects
> > > of
> to
> > > how
can
> > > Chris E
Message 8 of 15
Could you please then tell me how would you do this if you want to
filter all blocks with a string "E_" in the blockname. Is'nt it like
this the only way then?
Van: David Doane [mailto:[email protected]]
Gepost op: woensdag 2 februari 2000 20:12
Onderwerp: Re: SSGET PROBLEM
Frank,
selection
selection
set with ssdel.
hens
Dave D
selections
correct.
> > objects from it.
> > Good luck
> > Marcel Janmaat
think
> > is
objects
> > of
how
to
sure
> > how
can
> > Chris E
Message 9 of 15
Or is the other guy?
R. Robert Bell, MCSE
Network Administrator (or, Modern-day Wizard)
(remove the "not." in my address for direct e-mail)
Frank Oquendo wrote in message
news:[email protected]...
fields
a
> little myopic.
> > Frank,
> selection
selection
> > set with ssdel.
> hens
> > Dave D
> selections
> > correct.
> > > > objects from it.
> > > > Good luck
> > > > Marcel Janmaat
> think
> > > > is
> objects
> > > > of
how
> > to
sure
> > > > how
> can
> > > > Chris E
Message 10 of 15
Selection set filters allow for the use of wildcards: (ssget "X" '((0 .
"INSERT")(2 . "E_*")))
news:048CF107BE98D211A6440008C7456EA30F2DBC@HE-MAILSRV...
> Frank,
> selection
> selection
> set with ssdel.
> hens
> Dave D
> selections
> correct.
> > > objects from it.
> > > Good luck
> > > Marcel Janmaat
> think
> > > is
> objects
> > > of
> how
> to
> sure
> > > how
> can
> > > Chris E
Message 11 of 15
Well then,
Since you guys appear to be the experts on this, could you please tell
me then how i can filter all blocknames wich contain the string "E_" in
the filename. How can i put this in the ssget command.
Van: R. Robert Bell [mailto:[email protected]]
Gepost op: woensdag 2 februari 2000 20:47
fields
I'm
a
> little myopic.
> > Frank,
> selection
selection
> > set with ssdel.
the
> hens
> > Dave D
> selections
are
> > correct.
reguiered
> > > > objects from it.
> > > > Good luck
> > > > Marcel Janmaat
I
> think
> > > > is
> objects
> > > > of
know
how
> > to
not
sure
> > > > how
to be
or
> can
> > > > Chris E
Message 12 of 15
Thanks!
I did 'nt know wildcards were alowed.
Van: Frank Oquendo [mailto:[email protected]]
Gepost op: woensdag 2 februari 2000 20:52
> Frank,
> selection
> selection
> set with ssdel.
> hens
> Dave D
> selections
> correct.
> > > objects from it.
> > > Good luck
> > > Marcel Janmaat
> think
> > > is
> objects
> > > of
> how
> to
> sure
> > > how
be
or
> can
> > > Chris E
Message 13 of 15
No problem.
Message 14 of 15
Hey! Notice how he said "appear" to be experts!
Marcel Janmaat wrote in message
news:048CF107BE98D211A6440008C7456EA30F2DFB@HE-MAILSRV...
> Well then,
> fields
> I'm
> a
> > little myopic.
> > > Frank,
> > selection
> selection
> > > set with ssdel.
> the
> > hens
> > > Dave D
> > selections
> are
> > > correct.
> reguiered
> > > > > objects from it.
> > > > > Good luck
> > > > > Marcel Janmaat
> I
> > think
> > > > > is
> > objects
> > > > > of
> know
> how
> > > to
> not
> sure
> > > > > how
> to be
> or
> > can
> > > > > Chris E
Message 15 of 15
Marcel,
(ssget '((0 . "INSERT")(2 . "E_*")))
Or, to select all block inserts in the drawing that do NOT start with "E_":
(ssget "X" '((0 . "INSERT")(2 . "~E_*")))
Matt
[email protected]
On Wed, 2 Feb 2000 21:01:53 +0100, Marcel Janmaat
wrote:
>Well then,
