ssget point list for "wp" or "cp selection
aliozcicek
Message 1 of 12
aliozcicek
can I ask you about smilar problem?
I have problem with "ssget" and "point list". after some code I got one point list like this....
((1322.2 31.6559) (1322.2 31.9501) (1313.8 31.9501) (1313.8 31.6559) (1314.04 31.4159) (1313.8 26.6457))
and I named it "ptlist" (also I have some other parameters for selection set like PAR1 PAR2.... )
(setq sec (ssget "CP" ptlist (list (cons 8 PAR1) (cons 40 PAR2) (cons 7 PAR3))))
when I use this code it is ending with
"; error: bad function: 1322.2"
where is my fault?
Accepted solutions (4)
Replies (11)
Message 2 of 12
pbejse
Should define your list as
like this
(setq ptlist '((1322.2 31.6559) (1322.2 31.9501) (1313.8 31.9501) (1313.8 31.6559) (1314.04 31.4159) (1313.8 26.6457))) not (setq ptlist (list (1322.2 31.6559) (1322.2 31.9501) (1313.8 31.9501) (1313.8 31.6559) (1314.04 31.4159) (1313.8 26.6457))) and not (setq ptlist ((1322.2 31.6559) (1322.2 31.9501) (1313.8 31.9501) (1313.8 31.6559) (1314.04 31.4159) (1313.8 26.6457)))
Message 3 of 12
Kent1Cooper
@aliozcicek wrote:
...". after some code I got one point list like this....
I was wondering the same thing as @pbejse, but I suppose the form of the list as shown above doesn't necessarily mean it wasn't constructed in the right way.  If the "some code" built the list as a variable, out of points from other variables and/or User picks, and you asked it to show you what's in the list variable, it would be shown like that, without  showing the apostrophe before the beginning that you would need if typing it into a (setq) function to define the list.
Is what's shown above the return from calling for what's in the variable at the command line, with the preceding exclamation point, like this?
!YourListVariableName
If not, can you post more of the code that defines the list?  Aside from the apostrophe question, what surrounds that may be incorrect in some other way -- a parentheses problem, or something -- making it arrive at that 1322.2 in a way that makes it think it's a function name and not an item in a list.
Kent Cooper, AIA
Message 4 of 12
aliozcicek
thanks for help guys.
I understand what I have only one member list when got,
((1322.2 31.6559) (1322.2 31.9501) (1313.8 31.9501) (1313.8 31.6559) (1314.04 31.4159) (1313.8 31.1759) (1313.8 26.6457) (1322.2 26.6457) (1322.2 31.1759) (1321.96 31.4159)) this.
and I extract it then I have all point list. now I can use it as point list.
for the take vertex coordinates I use that code (which I saw in autodesk forum before),
(defun massoc (key alist / x nlist)
(foreach x alist
(if (eq key (car x))
(setq nlist (cons (cdr x) nlist))
(reverse nlist)
(setq ptlst (massoc 10 (entget (car (entsel"\Seçim alanını seçiniz !")))))
(setq ptlst2 (car ptlst))
now I can set some spesific selection sets in any polyline.
Message 5 of 12
aliozcicek
something strange...
after I understand the stiuation I write same code but now it returns 10 member list. and I use it easily. I don't remember what I changed something but now it works as I expect...
(foreach x alist
(reverse nlist)
(ssget "_CP" ptlst)
really can't understand but it solved....
thanks anyway for recommendations...
Message 6 of 12
Kent1Cooper
If that is the way your 'ptlist' variable is defined, I don't see any reason why it shouldn't work for defining a Crossing-Polygon in an (ssget) function.  [There's a shorter way to get that point list from a Polyline, but the resulting list would be the same.]  I can think of reasons that nothing would be found, but not any reason for the error message you describe in Post 1....
[Never mind, if the problem has gone away.]
Kent Cooper, AIA
Message 7 of 12
Kent1Cooper
@aliozcicek wrote:
.... I don't remember what I changed something but now it works as I expect...
(ssget "_CP" ptlst)
Could it be the underscore character?  That lets English options and abbreviations work in non-English versions of AutoCAD, and it wasn't in the code in Post 1.
Kent Cooper, AIA
Message 8 of 12
aliozcicek
only now I see that differences. you might be right Kent Cooper,
another question in my mind. you think I have long way to get point list of polygon for creating sellection set in this polygon? actually I am such a begginner for lisp and I am trying to improve myself with all posts of this community.
let me show my aim.
  • there is one polygon ( actually I created it by another lisp).
  • in this polyygon I have some texts and blocks
  • I try to connect that bloks to texts and I then I need to extract to excell. this is need for my final account of current project.
dravings look like that... cyan one text... and other colors mean another blocks...
thanks for help and advices...
Message 9 of 12
Kent1Cooper
The shorter way that I would use would be like this:
(setq ptlst (vl-remove-if '(lambda (x) (/= (car x) 10)) (entget (car (entsel"\Seçim alanını seçiniz !")))))
without the need for that (massoc) function at all.  It defines a little nested function to check whether a list does not start with 10 [as the vertex entries do], and applies that to the entity data list, removing all such unwanted entries.  The inverse version also works:
(setq ptlst (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car (entsel"\Seçim alanını seçiniz !")))))
That one looks for entries that do  start with 10, and removes all the others.
Yes, it takes a while to get used to how (lambda) functions work in these things, but they can be powerful.
Kent Cooper, AIA
Message 10 of 12
aliozcicek
Thanks a lot Kent1Cooper,
I tried to use both vl-remove-if-not and lamda but couldn't make it work. I was know that command what I need 🙂 I understand some codes really powerfull as you say and I clearly understand I need little more time. but will be fun.
thanks for all...
Message 11 of 12
devitg
I shall say I do not read all post , but for a SSGET cp or wp, fence , all points SHALL be on screen , or do a Zoom extend
Message 12 of 12
aliozcicek
yes devitg you right.. this is another key point which I missing... now I understand well why my codes doesn't work anytime.
thanks...
