ssget on layer with strange name
bcddss
bcddss
hi,
I have a ssget formula to select all from a layer. But if the layer name is like "[342]", the function return nil. Can help me someone? Thank you.
Ahags
cadffm
what a great idea to use wildcard characters in named objects 🙂
read more about autocad WILDCARDS, f.e. here: https://help.autodesk.com/view/ACD/2022/DEU/?guid=GUID-EC257AF7-72D4-4B38-99B6-9B09952A53AD
[342] => (ssget "_X" '((8 . "`[342`]")))
Sebastian
bcddss
i have a lisp and not reading the layer with wild cards returning nil. I don't use that wild cards in my drawings. they came from outside!  😄
Ahags
cadffm
they came always from outside or a Co-workers 😁
Sebastian
bcddss
something like that:
(setq LAY (cdr (assoc 8 (entget e))))
(ssget "_X" (list (cons 8 LAY))
so, how do i make the LAY variable to be useable?
Ahags
cadffm
You have to edit the string "[342]" this way that the result looks like "`[342`]"
So you have to write a function that check each char in your string and if it is an wildcard character,
add a "`" char to the string in front of this char.
Create the function to work with all wildcards, otherwise you will stumpled next over a layer with name "123.4"
or "wow#****" and so on.
For a very practiced one it is just a single line code,
but it is okay if you need 10 or 50 lines. Importend is just the result!
As starter for you:
(defun MyOwnQuoteStr (STR)
(mapcar 'chr (vl-string->list STR))
Try this: (mapcar 'chr (vl-string->list LAY))
Now, you can use FOREACH (or mapcar or whatever)
{sorry, I like to help programming, but not by publish the whole solution}
Sebastian
bcddss
thank you, i will make the function. Good day!
 i think i use the Lee Mac function 😅
http://www.lee-mac.com/escapewildcards.html
Ahags
