SSGET Error "*Invalid Selection*"
drew_dewit
drew_dewit
All,
I am suddenly getting an error when I use the following function:
(defun removetext ()
(command "_.erase" (ssget "X" '((0 . "TEXT,MTEXT"))))
(princ "\nText removed from drawing")
The error is:
*Invalid selection*
Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle/SUbobject/Object
1 found
I believe it to be the ssget function. It had worked before but now it only seems to work in a specific drawing. Any idea why it is suddenly generating this error?
cadffm
The message comes from the started command (ERASE)
and only when no valid selection has been made.
No
1. TEXTS and MTEXT exist
2. on unlocked layers
3. in the current space
offtopic
Should the command automatically delete (M) text? Then you forgot to finish the object selection.
Better, but still without layer handling
(defun removetext (/ ss)
(if (setq ss (ssget "_X" (list '(0 . "TEXT,MTEXT")(cons 410 (getvar 'CTAB)))))
     (progn
         (command "_.ERASE" ss "")
(princ)
handle layer (locked/unlocked) an use ENTDEL would be the next evolution..
Sebastian
