ssadd issue
ssadd issue
zph
Message 1 of 14
ssadd issue
zph
Good day!
I am having an issue with the following bit of code:
(foreach x i3List
(if (equal (cadr x) tVal) (setq ssCs (ssadd (car x) ssCs)))
) ;foreach
i3List - list containing sublists with two elements each; car is a text entity's ename, cadr is its value (assoc 1).
EDIT: an example of one of the sublists:
(<Entity name: 7ffffb068e0> CABLE-NUM-001)
If the cadr of the sublist is equal to the text value tVal, I want to create (and add to) selection set ssCs.
If I replace the code in red with (princ "\n test"), the routine finishes as intended...currently, it stops at 'ssadd'.
Do you guys know why?
Replies (13)
Message 2 of 14
ВeekeeCZ
I would expect value of (cdr (assoc 1)) as a string.
(<Entity name: 7ffffb068e0> "CABLE-NUM-001")
but what value is tVal?
Also you need to create empty ssCs first: (setq ssCs (ssadd)), then you can add ents to it.
Message 3 of 14
Kent1Cooper
You don't show how the tVal variable is set, or an example of that by itself, nor what kind of value is represented by the second item in a sublist.  But if tVal is, as you describe, a text value, then it would presumably be a string variable.  Try either:
a)  setting the second-item value in the sublist in a way that makes it a string for the comparison;
or:
b)  un-stringifying the tVal variable for the comparison:
  (if (equal (cadr x) (read tVal)) ...
Also [this is probably not the cause of the problem you describe, but...], you don't need to surround the (ssadd) function with a (setq) function -- (ssadd) changes what's in the selection-set variable without that.  Try [assuming you use approach a) above, in which case (=) is enough for the comparison]:
  (if (= (cadr x) tVal) (ssadd (car x) ssCs))
Kent Cooper, AIA
Message 4 of 14
zph
The test (if) function isn't the issue (I think), because when I use a true test case, the function acts appropriately. The way the result is handled seems to be the issue, or at least the way I've applied the ssadd function.
I added your "(setq ssCs (ssadd))" before each instance and this permitted the routine to finish successfully.
One question, though, does "(setq ssCs (ssadd)" effectively 'reset' ssCs to an empty selection set (if there is already entities contained within)?
Message 5 of 14
zph
The variable 'tVal' is purely the result of (cdr (assoc 1 (ssname....
Message 6 of 14
Ranjit_Singh
yes, it resets ssCs to empty set
Message 7 of 14
Kent1Cooper
@zph wrote:
....does "(setq ssCs (ssadd)" effectively 'reset' ssCs to an empty selection set (if there is already entities contained within)?
Yes [though it would need another right parenthesis at the end] -- read about (ssadd) with no arguments in Help.
Kent Cooper, AIA
Message 8 of 14
zph
It seems that
(setq ssCs (ssadd))
is not the same as
(setq ssCs nil)
EDIT:  it seems that the 'type' of empty is different.  (ssadd) is to create an empty selection set while 'nil' creates an empty variable
Message 9 of 14
Kent1Cooper
Then I can only assume your sublist example in Post 1 is not showing the double-quotes that such a list would actually contain, as both BeekeeCZ and I suggested in red in Posts 2 & 3.
Kent Cooper, AIA
Message 10 of 14
Ranjit_Singh
setq ssc nil basically resets ssc to nil (nothing). whereas, setq ssc (ssadd) makes an empty selection set. So you can think of an empty container object with no items inside. But with setq ssc nil there is no container object, there is nothing. Maybe someone else can explain it better.
Message 11 of 14
zph
My routine functions without the double quotes. This may be due to the use of 'EQUAL' rather than =.
I try to use 'EQUAL' for comparisons between two text values and '=' for comparisons between numeric values.  Is there a better way?
Message 12 of 14
Kent1Cooper
@zph wrote:
It seems that
(setq ssCs (ssadd))
is not the same as
(setq ssCs nil)
Absolutely -- an empty selection simply has 0 items in it, but it still "exists":
Command: (setq test (ssadd))
<Selection set: f7>
Command: !test
<Selection set: f7>
Command: (sslength test)
0
whereas
Command: (setq test nil)
nil
Command: !test
nil
; error: bad argument type: lselsetp nil
This is the same as with text strings [an empty one is "", but still exists], but is not the same as with lists [making an empty list returns nil, and if you remove things from a list variable until it's empty, it ceases to exist].
Kent Cooper, AIA
Message 13 of 14
Kent1Cooper
Does whatever creates those sublists actually make them without double-quotes?  I'm surprised, if it's coming from (assoc 1 ... for any entity type I can think of.  We still haven't seen how 'tVal is set -- is it actually a string, or has it been un-stringified?  A comparison of a text string with its non-string equivalent does not work, for me:
Command: (equal "THIS" (read "THIS"))
nil
Read about (=) in help -- the arguments can be numbers or strings.  I use it for simple string comparisons instead of (equal) because it's shorter and just as effective -- (equal) is needed only for more complicated circumstances [comparing lists, or numbers with a fuzz factor].
Kent Cooper, AIA
Message 14 of 14
zph
tVal is a string derived from the STRCAT function.
I thought tVal was (cdr (assoc 1 (ssname..., but I was mistaken...this was a different routine.
However, the STRCAT function is concatenating two string derived from multiple uses of SUBSTR and (cdr (assoc 1 (ssname....
