Split area of polyline into several portions at once
nuweariho123
Message 1 of 14
nuweariho123
Hello here,
I was recently doing a subdivision of land plots into certain sizes repeatedly and realized it was tiresome.
Please someone help with a Lisp that splits area of a closed polyline into several equal sized portions basing in users direction of splitting (using a single line to show the direction of splitting).The n after splitting the land into the required size of portions.It creates boundaries for each plot.
Thank you..🙏🙏
Replies (13)
Message 2 of 14
Patchy
Message 3 of 14
cadffm
and a lot more sample if you use wwww search engines  for
autocad Split area of polyline into several portions
autocad Split area of portions
or similar phrases
Sebastian
Message 4 of 14
nuweariho123
the problem I find is that the process is to be done manually.
you have to keep splitting into half instead of splitting into required sized portions at once.
For example this .VLV below splits into two at any one time instead I need one which creates Several required sized portions at once
Message 5 of 14
Sea-Haven
The splitting lots has been around for a long time, its not just a simple area answer, there are other options, 1st is easy a simple rectang style by area, others are area by swing brg, set frontage of lot similar to swing brg, I know about these as they were in other software like in the 80's. CIV3D, Stringer Civil Site design have a look at them.
Have a look at this Subdivision Creation Process in Civil3D - YouTube
Like the others do a Google.
Message 6 of 14
nuweariho123
the problem I find is that the process is to be done manually.I acknowlege the fact that lisp commands do it faster
For example this splitarea .VLX below attached splits into two at any one time instead I need one which creates Several required sized portions at once
also the parcel creation tools also
Message 7 of 14
vladimir_michl
"This" SplitArea.vlx file is in fact this one:
https://www.cadstudio.cz/en/apps/splitarea/
And the latest version of SplitArea is free for all type if splits/divisions (no more limited to just 2 parts).
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
Message 8 of 14
nuweariho123
please send the link to the updated one
Message 9 of 14
vladimir_michl
Version 1.5 available on the mentioned product page is the latest one (and free).
Message 10 of 14
nuweariho123
I have attached a video explaining my problem.
thank you
Message 11 of 14
nuweariho123
here
Message 12 of 14
Kent1Cooper
Are you always doing this in rectangular starting boundaries?
Kent Cooper, AIA
Message 13 of 14
nuweariho123
No I used a rectangle as a simple illustration.
But it can be any polygon shape even irregular.
Message 14 of 14
vladimir_michl
The Acreage and Border options cannot be used for multiple divisions, they just cut the specified acreage from the selected lot. But you can use them repeatedly. For splitting the source lot in multiple parts in one go, use the Number and Division options. Pleas note that specifying the acreage cannot split the lot into multiple parts with the SAME area (except special cases which can be covered by the Number option).
