SPLine circle to normal circle
Henrik_Lo
Message 1 of 9
Henrik_Lo
Hi
Is the a LISP routine out there to changing this special holes to normal circle by itself.
I have a lot of them
Regards
Henrik
Replies (8)
Message 2 of 9
_gile
Here's a 'quick and dirty':
(defun c:SPL2CRCL (/ ss i)
  (if (setq
	ss (ssget
	     '((0 . "SPLINE") (-4 . "&") (70 . 13) (71 . 2) (73 . 9))
    (repeat (setq i (sslength ss))
      (Spline2Circle (ssname ss (setq i (1- i))))
  (princ)
(defun midPoint	(p1 p2)
  (mapcar '(lambda (x1 x2) (/ (+ x1 x2) 2.)) p1 p2)
(defun Spline2Circle (spl / p0 p4 c r)
  (setq
    p0 (getpropertyvalue spl "ControlPoints" 0 "Position")
    p4 (getpropertyvalue spl "ControlPoints" 4 "Position")
    c  (midPoint p0 p4)
    r  (distance c p0)
  (entdel spl)
  (entmakex
    (list
      (cons 0 "CIRCLE")
      (cons 10 c)
      (cons 40 r)
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 9
paullimapa
Found this TT code by doing a search on-line for "autolisp spline to circle" and it works on your posted sample drawing.
Paul Li
IT Specialist
@The Office
Message 4 of 9
Henrik_Lo
Hi _Gile
It works, simply fantastic, tangs for helping me out, thangs
Have a nice weekend
Regards
Henrik
Message 5 of 9
Henrik_Lo
Hi paullimapa
It works too, fantastic, tangs for helping me out, thangs
Have a nice weekend
Regards
Henrik
Message 6 of 9
paullimapa
You’re welcome and cheers!!!
Paul Li
IT Specialist
@The Office
Message 7 of 9
Kent1Cooper
Another way [in simplest terms]:
(defun C:S2C (/ ss n spl LL UR)
  (if (setq ss (ssget '((0 . "SPLINE"))))
    (repeat (setq n (sslength ss))
      (setq spl (ssname ss (setq n (1- n))))
      (vla-getboundingbox (vlax-ename->vla-object spl) 'minpt 'maxpt)
      (setq
        LL (vlax-safearray->list minpt)
        UR (vlax-safearray->list maxpt)
      (command
        "_.circle" "_non" (mapcar '/ (mapcar '+ LL UR) '(2 2 2)) (/ (- (car UR) (car LL)) 2)
        "_.erase" spl ""
  (prin1)
It uses the centers of the bounding boxes for the Circles' centers, and half the width of that for their radii.  It's up to you to select appropriate Splines, but it could be made to check for certain things, such as that the bounding box at least has the same width and height [within some tolerance].  It draws the Circle(s) on the current Layer, but could put each on the same Layer as its source Spline.  Etc., etc.
Kent Cooper, AIA
Message 8 of 9
_gile
Nice trick @Kent1Cooper
I had some fun digging into NURBS, trying to generalize to ellipses (circles being particular ellipses).
(defun SplineToCircleOrEllipse
       (spl / massoc elst ctrlPts sqrt05 p0 p2 p4 p6 ctr r1 r2 v1 v2)
  (defun massoc	(key alst)
    (if	(setq alst (member (assoc key alst) alst))
      (cons (cdar alst) (massoc key (cdr alst)))
  (setq	elst	(entget spl)
	ctrlPts	(massoc 10 elst)	; control points
	sqrt05	(sqrt 0.5)
  ;; check the spline validity
  (if (and
	(= (cdr (assoc 0 elst)) "SPLINE") ; Spline
	(= (logand (cdr (assoc 70 elst)) 13) 13) ; planar rational closed
	(= (cdr (assoc 71 elst)) 2)	; quadratic
	(= (length ctrlPts) 9)		; number of control points
	(equal (massoc 41 elst)		; weights
	       (list 1. sqrt05 1. sqrt05 1. sqrt05 1. sqrt05 1.)
	(setq p0  (nth 0 ctrlPts)
	      p2  (nth 2 ctrlPts)
	      p4  (nth 4 ctrlPts)
	      p6  (nth 6 ctrlPts)
	      ctr (inters p0 p4 p2 p6)
	      r1  (distance ctr p0)
	      r2  (distance ctr p2)
	      v1  (mapcar '- p0 ctr)
	      v2  (mapcar '- p2 ctr)
	(equal (apply '+ (mapcar '* v1 v2)) 0 1e-10) ; perpendicular axis
    (entmakex
      (if (equal r1 r2 1e-12)
	(list
	  '(0 . "CIRCLE")
	  (cons 10 (trans ctr 0 (cdr (assoc 210 elst))))
	  (cons 40 r1)
	  (assoc 210 elst)
	(list
	  (cons 0 "ELLIPSE")
	  (cons 100 "AcDbEntity")
	  (cons 100 "AcDbEllipse")
	  (cons 10 ctr)
	  (cons 11 (mapcar '- p0 ctr))
	  (assoc 210 elst)
	  (cons 40 (/ r2 r1))
The reverse process
;; MakeEllipticalSpline
;; Makes a planar rational closed cubic Spline figuring a Circle or an Ellipse.
;; Returns the created Spline ename or nil.
;; Arguments
;; center: Center of the ellipse.
;; majAxis; Major axis vector.
;; majAxis; Minor axis vector (must be perpendicular to majAxis).
(defun MakeEllipticalSpline (center majAxis minAxis / ctrlPts sqrt05)
  ;; check if axis are perpendicular
  (if (equal (apply '+ (mapcar '* majAxis minAxis)) 0 1e-10)
    (progn
      (setq ctrlPts (list
		      (mapcar '+ center majAxis)
		      (mapcar '+ center majAxis minAxis)
		      (mapcar '+ center minAxis)
		      (mapcar '+ center (mapcar '- majAxis) minAxis)
		      (mapcar '- center majAxis)
		      (mapcar '- center majAxis minAxis)
		      (mapcar '- center minAxis)
		      (mapcar '+ center majAxis (mapcar '- minAxis))
	    sqrt05  (sqrt 0.5)
      (entmakex
	(append
	  (list
	    (cons 0 "SPLINE")
	    (cons 100 "AcDbSpline")
	    (cons 70 13)		; planar rational closed
	    (cons 71 2)			; quadratic
	    (cons 72 12)		; number of knots
	    (cons 73 9)			; number of control points
	  (mapcar '(lambda (x) (cons 40 x)) ; knots
		  '(0 0 0 1 1 2 2 3 3 4 4 4)
	  (mapcar '(lambda (x) (cons 41 x)) ; weights
		  (list 1 sqrt05 1 sqrt05 1 sqrt05 1 sqrt05 1)
	  (mapcar '(lambda (x) (cons 10 x)) ctrlPts) ; control points
;; CircleOrEllipseToSpline
;; Makes a planar rational closed quadratic Spline from a Circle or an Ellipse.
;; Returns the ename of the created entity or nil.
;; Argument
;; ent: Circle or Ellipse ename
(defun CircleOrEllipseToSpline (ent / elst normal majAxis minAxis)
  (cond
    ((= (cdr (assoc 0 (setq elst (entget ent)))) "CIRCLE")
     (setq normal  (cdr (assoc 210 elst))
	   majAxis (list (cdr (assoc 40 elst)) 0. 0.)
	   minAxis (list 0. (cdr (assoc 40 elst)) 0.)
     (MakeEllipticalSpline
       (trans (cdr (assoc 10 elst)) normal 0)
       (trans majAxis normal 0 T)
       (trans minAxis normal 0 T)
    ((= (cdr (assoc 0 elst)) "ELLIPSE")
	   ratio   (cdr (assoc 40 elst))
	   majAxis (cdr (assoc 11 elst))
	   minAxis (trans (mapcar
			    '(lambda (x) (* x ratio))
			    ((lambda (v)
			       (list (- (cadr v)) (car v) (caddr v))
			      (trans majAxis 0 normal)
			  normal
			  0
       majAxis
       minAxis
Gilles Chanteau
GileCAD
GitHub
Message 9 of 9
Henrik_Lo
Hi Thangs for replying, super
Regard
Henrik
