Message 1 of 18
A code like the following sould be usefull.
A lisp code , starts execution asking for an intemidiate polyline point (a point between two vertices).
After the Point defined, polyline breaks only in that part (between the two vertices).
So , after execution there will be one line (the broken section of polyline) and perhaps one (if polyline where closed ) or two (if was not closed) remaining parts of the "broken poly". If there will be two parts , then , both of them will retain their previous direction.
Gery.
