Special Char in script error
PanzerRanger
PanzerRanger
When I run a script trying to merge layers it cause the layername to be incorrect when it contains swedish (special) characters like ä
Select object on layer to merge or [Name/Undo]: name
Enter layer name or [?]: "Anläggningsnummer annan text (ritning)"
Invalid Layer name.
The layername should be "Anläggningsnummer annan text (ritning)"
It works fine creating the layers.
Is it possible to solve this and still have special characters in the layername?
CodeDing
@PanzerRanger,
Not sure why it would act that way. Perhaps try adding this AutoLISP code to your script. Works for me (Civil 3D 2018 - English).
;START
(setq lay2merge "Anläggningsnummer annan text (ritning)")
(setq targetLayer "0")
(command "-LAYMRG" "N" lay2merge "" "N" targetLayer "Y")
;END
Best,
~DD
