hi ALL,
I use this script to plot all blocks named "!MineMyA". However, I do not know the order the script plot the blocks.
Please can you modify the script to plot in the y direction (from top to bottom) without caring for x direction.
For example, in the attached drawing it polts the blocks in the order of its creation or insertation as I noticed.
This is the used script ( it is attached as well)
(vl-load-com)
(defun c:Demoy (/ dwg file hnd i len llpt lst mn mx ss tab urpt)
(if (setq ss (ssget "_X" '((0 . "INSERT") (2 . "!MineMyA"))))
(progn
(repeat (setq i (sslength ss))
(setq hnd (ssname ss (setq i (1- i)))
tab (cdr (assoc 410 (entget hnd)))
lst (cons (cons tab hnd) lst)
(setq lst (vl-sort lst '(lambda (x y) (> (car x) (car y)))))
(setq i 0)
(foreach x lst
(setq file (strcat (getvar 'DWGPREFIX)
(substr (setq dwg (getvar 'DWGNAME)) 1 (- (strlen dwg) 4))
(itoa (setq i (1+ i)))
".pdf"
(if (findfile file)
(vl-file-delete file)
(vla-getboundingbox (vlax-ename->vla-object (cdr x)) 'mn 'mx)
(setq llpt (vlax-safearray->list mn)
urpt (vlax-safearray->list mx)
len (distance llpt (list (car urpt) (cadr llpt)))
(command "-plot"
"yes" ;Detailed Plot Configuration?
(car x) ;layout
"DWG TO PDF.PC3" ;Printer Name
"ISO expand A3 (420.00 x 297.00 MM)" ;Paper Size
"Millimeters" ;Paper Units
"Landscape" ;Orientation
"No" ;Plot Upside Down?
"Window" ;Plot Area
(trans llpt 0 1) ;x coordinate
(trans urpt 0 1) ;y coordinate
"Fit" ;Plot Scale
"Center" ;Plot Offset
"yes" ;Plot With Plotstyle?
"monochrome.ctb" ;Plot Style Name
"Yes" ;Plot Lineweights?
"" ;Enter shade plot setting ["As displayed"/"Wireframe"/"Hidden"/"Visual styles"/"Rendered"]
(if (/= (car x) "Model") ;Automatic pdf file name
(command "No" "No" file "no" "Yes")
(command
file
"no" ;Save changes to page setup
"Yes" ;Proceed with plot
(princ)
Thank you
