Sort layout by name
Sort layout by name
LeoManu
Sort layout by name
LeoManu
Hi, I'm looking for a LISP to sort the layouts in numerical order, for example:
8, 5, 22, 13, 16, 150, 3, 1, 24.
It should end up as:
1, 3, 5, 8, 13, 16, 22, 24, 150.
Thanks!
Sea-Haven
Do you mean move the layouts so visually in correct order ?
TabSort | Lee Mac Programming (lee-mac.com)
LeoManu
Yes, I mean to move the tabs of each layout so that they appear in order
komondormrex
hey there,
for layouts whose names are stringed integers.
(defun c:sort_num_layouts (/ layouts layout_list index)
	(vlax-map-collection (setq layouts
								(vla-get-layouts
									(vla-get-activedocument
										(vlax-get-acad-object)
		'(lambda (layout)
			(setq layout_list (cons (vla-get-name layout) layout_list))
	(setq layout_list (vl-sort (mapcar 'atoi (vl-remove "Model" layout_list)) '<)
		  index 1
	(foreach layout layout_list
		(vla-put-taborder (vla-item layouts (itoa layout)) index)
		(setq index (1+ index))
	(princ)
LeoManu
Thank you so much, it was exactly what I needed!
