Move Layers By X Distance
LeoManu
Message 1 of 9
LeoManu
Hello, I have a DWG file with a lot of pages stacked on top of each other, and I would like to separate them by a distance X to work with them more easily. Each page is on a different layer, so it's possible to move them by selecting the layer corresponding to each page. The title block is on layer 0 and is the same for all pages and should be copied to each of the existing pages. I have attached a DWG file with more details. I managed to make some progress with the following code, but I can't seem to sort them by name as they appear in the layer properties. I would like the pages to be moved in the correct order. Thank you very much.
(defun c:MoveLayersByXDist ()
  (prompt "\nEnter the 'X distance' value: ")
  (setq xDist (getreal))  ; Prompts the user to enter the X distance
  (if (not xDist)
    (progn
      (prompt "\nError: A numeric value is required for 'X distance'.")
      (exit)
  (setq layers (getLayers)  ; Get a list of all layers
        counter 1  ; Counter to multiply the distance
        selectionLayer0 (ssget "X" (list (cons 8 "0")))  ; Select all objects on layer "0"
        distances '())  ; List to store copy distances
  ; Move all layers except "0" and "1"
  (foreach layer layers
    (if (not (member layer '("0" "1")))  ; Ignore layers "0" and "1"
      (progn
        (setq selection (ssget "X" (list (cons 8 layer))))  ; Select all on the current layer
        (if selection
          (progn
            (setq distance (* counter xDist))  ; Calculate the move distance
            (command "_.move" selection "" "0,0,0" (strcat (rtos distance 2 6) ",0,0"))  ; Move the selection
            (setq distances (cons distance distances))  ; Store the copy distance
            (setq counter (1+ counter))  ; Increment the counter
  ; Copy the contents of layer "0" according to the accumulated distances
  (if selectionLayer0
    (foreach distance (reverse distances)  ; Iterate over the distances in order
      (command "_.copy" selectionLayer0 "" "0,0,0" (strcat (rtos distance 2 6) ",0,0"))
  (princ "\nLayer movement and layer '0' copy process completed.")
  (princ)
(defun getLayers ()
  (setq layerList '())
  (vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
    (setq layerList (cons (vla-get-name layer) layerList))
  (reverse layerList)
Replies (8)
Message 2 of 9
Sea-Haven
You seem to have 3 posts all asking for a solution to your dwg problem. Where you want layouts made by layer.
Create a New Layout for Each Existing Layer - Autodesk Community - AutoCAD
There is no need to do multiple posts you can ask more at one post.
Message 3 of 9
LeoManu
Sorry, I didn't mean to mix different methods. In that post, the solution would be without modifying the model, which seemed more complicated than just moving the layers in the model. And the last one is about a different topic, which is reorganizing layers by name.
Message 4 of 9
Kent1Cooper
@LeoManu wrote:
.... I can't seem to sort them by name as they appear in the layer properties. .....
Do you mean alphabetically?  That's only the default order.  You can have them appear in different orders by picking on different column headings to sort by, so "as they appear" is not a constant.
Kent Cooper, AIA
Message 5 of 9
Moshe-A
@LeoManu hi,
here is my version 😀
instead of using (getreal), i use (getdist) which also allows you to specify the distance on screen.
plus, instead of selecting all objects for each layer which could select other objects you do not want, i am giving the user to select all objects involve and then filter objects by layer.
to change the position of the content (layout), you need to specify a criteria?
enjoy
Moshe
(defun c:MoveLayersByXDist (/ getLayers filterByLayer  ; local functions
			      xDist ss0 ss1 ctr lay)
 (defun getLayers (/ tbl layerList)
  (while (setq tbl (tblnext "layer" (not tbl)))
   (setq layerList (cons (cdr (assoc '2 tbl)) layerList))
  (reverse layerList)
 ); getLayers
 (defun filterByLayer (s0 lay / i s0 ent)
  (setq i -1 s1 (ssadd))
  (repeat (sslength s0)
   (if (eq (strcase (cdr (assoc '8 (entget (setq ent (ssname s0 (setq i (1+ i)))))))) (strcase lay))
    (ssadd ent s1)
  ); repeat
  s1
 ); filterByLayer
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (if (and
       (setq xDist (getdist "\nEnter the 'X distance' value: "))
       (setq ss0 (ssget)) ; select all objects involve in this commnd
  (if (and
	(setq ss1 (filterByLayer ss0 "0")) ; select all on layer zero
	(setq ctr 0)
   (foreach lay (vl-sort (getLayers) (function (lambda (e0 e1) (< (atoi e0) (atoi e1)))))
    (if (and
	  (null (member lay '("0" "1")))
	  (setq ss2 (filterByLayer ss0 lay))
     (progn
      (setq ctr (1+ ctr))
      (command "._copy" "_si" ss1 "0,0" (polar '(0.0 0.0 0.0) 0.0 (* xDist ctr)))
      (command "._move" "_si" ss2 "0,0" (polar '(0.0 0.0 0.0) 0.0 (* xDist ctr)))
    ); if
   ); foreach
  ); if
 ); if
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
); c:MoveLayersByXDist
Message 6 of 9
komondormrex
hello again,
and another one
  (setq xDist (getdist))  ; Prompts the user to enter the X distance
  (if (not xDist)
    (progn
      (exit)
  (foreach layer (mapcar 'cdr layers)
      (progn
        (if selection
          (progn
            (setq distance_ (* counter xDist))  ; Calculate the move distance
            (command "_.move" selection "" "0,0,0" (strcat (rtos distance_ 2 6) ",0,0"))  ; Move the selection
            (setq distances (cons distance_ distances))  ; Store the copy distance
  (if selectionLayer0
    (foreach distance_ (reverse distances)  ; Iterate over the distances in order
      (command "_.copy" selectionLayer0 "" "0,0,0" (strcat (rtos distance_ 2 6) ",0,0"))
  (princ)
(defun normalize_layer_name (name)
	(if (vl-every '(lambda (ascii_) (member ascii_ (vl-string->list "0123456789"))) (vl-string->list name))
		(strcat (substr "0000" 1 (- 4 (strlen name))) name)
		(strcat (substr "0000" 1 (- 4 (strlen (substr name 1 (vl-string-search "_" name))))) name)
(defun getLayers (/ layerList)
    (setq layerList (append layerList (list (cons (normalize_layer_name (vla-get-name layer)) (vla-get-name layer)))))
  (vl-sort layerList '(lambda (layer_1 layer_2) (< (car layer_1) (car layer_2))))
Message 7 of 9
Kent1Cooper
@Kent1Cooper wrote:
..... Do you mean alphabetically?  That's only the default order.  ....
If so, and if you can stand having "5_REV_00" coming before just-plain "5", then here's my take on it [minimally tested in your sample drawing]:
(defun C:WHATEVER (/ xDist LayName LayList border inc ss)
  (while (not xDist) (setq xDist (getdist "\nX-direction spacing distance: ")))
  (while (setq LayName (cdr (assoc 2 (tblnext "layer" (not LayName)))))
    (if (not (wcmatch LayName "0,1,Defpoints,*|*"))
      ; not those to not move nor Defpoints nor Xref-dependent [last 2 teste expendable?]
      (setq LayList (cons LayName LayList))
    ); if
  ); while
  (setq
    border (ssget "_X" '((8 . "0")))
    inc 0
    LayList (vl-sort Laylist '(lambda (x y) (< (atoi x) (atoi y))))
  ); setq
  (foreach LayName LayList
    (if (setq ss (ssget "_X" (list (cons 8 LayName)))); has object(s)
      (command
        "_.move" ss "" (polar '(0 0 0) 0 (* xDist (setq inc (1+ inc)))) ""
        "_.copy" border "" (polar '(0 0 0) 0 (* xDist inc)) ""
      ); command
    ); if
  ); foreach
  (prin1)
It counts on your having all Layer names as numbers or starting with numbers.  The reason "5_REV_00" comes before "5" is that it's how (vl-sort) handles them comparatively when sorting by (atoi) on the Layer name.  The compensating advantage over sorting alphabetically is that "150" comes at the end, not before all Layers except "1", and "20" before "3".  It could be made to put "5_REV_00" after "5" with more code, but doing it as it does is one reason it's comparatively short.
A couple of comments:
You can incorporate the prompt for X spacing right into the (getdist) function, and if you use that instead of (getreal), you can pick the distance on-screen if you want, in addition to being able to type in a value.  It will handle refusing non-numerical input itself, so mine only has to handle the possibility of Enter [nil return], which results in it asking again.
It doesn't wait to ignore Layers 0 and 1 in the Moving part, checking every Layer name before proceeding, but omits them from the list of Layers to work on as it makes that list.  And your starting (setq layerList '()) does nothing -- there is no such thing as a list with nothing in it, but such a thing is simply nil [it doesn't exist].  Yes, a text string can be empty and still exist, and also a selection set, but not a list.
It doesn't bother making a list of distances that it then has to go through later to Copy the Layer-0 stuff to each location, but rather just copies the Layer-0 stuff right along with Moving the other-Layer stuff each time.
Kent Cooper, AIA
Message 8 of 9
LeoManu
Thanks everyone for your help, the code worked perfectly and will help me to study it in depth!
Message 9 of 9
komondormrex
jist to stick it
	    (setq layerList (append layerList (list (cons (vla-get-name layer) (normalize_layer_name (vla-get-name layer))))))
	  (vl-sort layerList '(lambda (layer_1 layer_2) (< (cdr layer_1) (cdr layer_2))))
		  layers (getlayers)
		  selectionLayer0 (ssget "_x" '((8 . "0")))
		  index 1
	(foreach layer (mapcar 'car (vl-remove (assoc "0" layers) (vl-remove (assoc "1" layers) layers)))
		(if (setq selection (ssget "_X" (list (cons 8 layer))))
		          (progn
		            (command "_.move" selection "" "_di" (list (* index xDist) 0 0))
					(command "_.copy" selectionLayer0 "_m" "_si" "" (list (* index xDist) 0 0))
					(setq index (1+ index))
	(princ)
