SOMETHING RONG IN LIGHTING DISTREBUTION LISP ..
adellll
Message 1 of 8
adellll
I HAVE LIGHTING DISTREBUTION LISP AND ITS NOT WORK PROPERLY AND STOP WITH WARD (TRUE) AND NOT RESPONCE PLS...HELP AND THANKS
Replies (7)
Message 2 of 8
devitg
@adellll Please upload your sample.dwg , and show the error message.
Message 3 of 8
hak_vz
In RLA.lsp code after collecting values from dialog you there stands:
(if (and p1 p2 (= sd 1))
   (progn
    ;*** Execute Main Program ***
    (princ "\n True. ")
   );progn
This is incomplete lisp code, and all what it does is showing message "True" on command line.
Miljenko Hatlak
Message 4 of 8
adellll
THANKS FOR YOUR HELP...
Message 5 of 8
adellll
EXACTLY THIS CODE IS NOT WORK PROPERLY...THANKS
Message 6 of 8
adellll
I ATTACH THE FILE YOU REQUESTED.
Message 7 of 8
hak_vz
No, it works OK how it is written. But this is unfinished code and light distribution code is missing. This code is only demonstration of how dialog should be designed.  See original forum post here.
Miljenko Hatlak
Message 8 of 8
adellll
I try this code and test it stop and no reaction ..if you have a correct one you have already tested pls. send to me and I appreciate your reply to help me..
