snap grid lisp help
snap grid lisp help
ht23624
snap grid lisp help
ht23624
snap grid lisp doesn't work well. I want to make a lisp that changes the spacing of snap and grid at the same time. It doesn't work well. I'm a beginner in lisp, so please help me.
(defun c:s1()
(command "snap" "100" "")
(command "grid" "100" "")
(princ)
(defun c:s2()
(command "snap" "200" "")
(command "grid" "200" "")
(princ)
paullimapa
try this:
(defun c:s1()
(command "_.snap" "100")
(command "_.grid" "100")
(princ)
(defun c:s2()
(command "_.snap" "200")
(command "_.grid" "200")
(princ)
Now at the command prompt even in the middle of a command like LINE you can enter:
LINE
Paul Li
IT Specialist
@The Office
cadffm
less to do with lisp, command statements are nothing else then keyboard input (Acad recognise them as input in scripts, what is handled different than real manually keystrokes)
Open your program, let's test.
(command "snap" "100" "") =
(command  = send to commandline
"snap" = if in "" like here -> type SNAP in commandline and ENTER
"100" = if in "" like here -> type 100 in commandline and ENTER
"" =  -> type nothing and ENTER
Test it and type in (and one eye on screen to follow what you are doing)
Command: SNAP<enter>
Acad is asking for snap spacing, so answer!
Command: 100<enter>
and where we are now?
Isn't the command snap exit now, no commands running?
I think your last enter ("") in each (command-statement is too much)
HTH
Sebastian
ht23624
thank you so much
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
Kent1Cooper
I would do it this way:
(defun C:S1 ()
  (setvar 'snapunit '(100.0 100.0))
  (setvar 'gridunit '(100.0 100.0))
  (setvar 'gridmode 1)
(defun C:S2 ()
  (setvar 'snapunit '(200.0 200.0))
  (setvar 'gridunit '(200.0 200.0))
In addition to setting the sizes, they ensure that the Grid is turned on.
Since they don't use (command) functions, they can be used transparently, in the middle of another command, by prefixing the command name with an apostrophe:
'S1 or 'S2
Kent Cooper, AIA
Sea-Haven
Another idea,
(defun c:s1()
(princ)
(defun c:s0()
(command "_.snap" "off")
(command "_.grid" "off")
(princ)
You can do transparent commands with some commands so
Line 's1 pickpoints ...... so this will set snap & grid to 100.
Line 's0 pickpoints .... will turn snap off
Note the single quote 's1
