Block insert routine Autocad 2019
REALJOHNFROST
Message 1 of 8
REALJOHNFROST
Hie,
I am a novice lisp programmer. I am trying to make a routine to insert a block from other file. When i run the routine i receive a warning "Unable to insert a dependent block" and i don´t understand why.
Could you help me?
Regards.
(defun c:7B ()
(setq blkPath "C:\\Users\\xxx\\Dropbox\\Bloques.dwg")
(setq blkName "BQ_xxxx")
(command "_.-INSERT" (strcat blkPath "|" blkName) "0,0,0" 1 1 0)
(if (tblsearch "BLOCK" blkName)
(princ "\nBloque cargado correctamente. Ahora puedes insertarlo manualmente.")
(princ "\nError: No se pudo cargar el bloque.")
(princ)
Replies (7)
Message 2 of 8
cadffm
this command would trying to use a block from an Xref (xref Bloques, block BQ_xxx = "Bloques|bq_xxxx"
INSERT command can insert a blockreference of an internal block,
or you can create a block by insert another .dwg as block.
What you try is to use a block what is defined inside another .dwg.
Use command INSERTCONTENT instead INSERT
Read about both in [F1]
Sebastian
Message 3 of 8
REALJOHNFROST
Thanks so much. The problem is that command appeared in Autocad 2021 and i use 2019.
Regards.
Message 4 of 8
cadffm
Oups!
You running ACAD2019?
Sorry, INSERTCONTENT is a new command in ACAD2021, so you can't use it in 2019.
What you can do in 2019:
v1: Extract your Block(s) as separate .dwg file
Open Bloques.dwg, run WBLOCK, option Block, select your Block, select your target file [OK] (DO NOT CHANGE ANYTHING ELSE)
   This way you create a file "BQ_xxxx" and now, you can INSERT this file (as Block).
  You will find some tool like "WBLOCK ALL" to extract all blocks as separate .dwg file
another way
v2: You can INSERT "Bloques.dwg" as Block
Cancel the last INSERT-steps, instead of basepoint, send (command)
(command "_.-INSERT" blkPath)(command)
and then insert a blockreference of you block
(command "_.-INSERT" blkName "0,0,0" 1 1 0)
and run -PURGE to delete the unused stuff from Bloques
Sebastian
Message 5 of 8
cadffm
This post is for ACAD2021 and newer User ONLY:
INSERTCONTENT [F1]
Check the command workflow manually
Command: -INSERTCONTENT
External file path:D:\MyPath\MyBlockLib.dwg
Block name or [?]MyBlockName
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate/Explode/REpeat]:0,0
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>:1
Enter Y scale factor <use X scale factor>:1
Specify rotation angle <0>:0
Command:
all inputs packed into a command statement, results
(command "-INSERTCONTENT" "D:\\MyPath\\MyBlockLib.dwg" "MyBlockName" "0,0,0" 1 1 0)
or force to work in all international language versions, forces the oiriginal command, insert in WCS 0,0,0:
(command "_.-INSERTCONTENT" "D:\\MyPath\\MyBlockLib.dwg" "*0,0,0" 1 1 0)
Sebastian
Message 6 of 8
REALJOHNFROST
Thanks! I try step by step and i have a warning when i execute this code. The warning is wrong function and appear and strange folder in the command line: "C:UUsersXXXDesktop@1BLOQUEDIN_7982.dwg", is like not understand the folder or somthing like that.
(defun c:8T ()
(princ)
;; Ruta del archivo que contiene los bloques
(setq blkPath "C:\Users\XXX\Desktop\1001\BLOQUE\DIN_7982.dwg")
;; Nombre del bloque a cargar
(setq blkName "DIN_7982")
;; Cargar el bloque desde el archivo externo
(command "_.-INSERT" (blkPath))
;;(command "_.-INSERT" (blkname "0,0,0" 110)
Message 7 of 8
cadffm
basic rule in lisp(strings), a backslash is a controle character! If you want a backslash in strings, like in your path,
you have to quote them.
How? Backslash is the controle character for quote, so you need a double backslash
\\ instead of \
for path informations, you can also use a Slash /
See your or my samples above!
Another issue in your code is (blkPath).
Without explaination, use blkPath, without ( )
Followed by (command)
to cancel the insert command.
Later, if it works
(command "_.-INSERT" blkname "0,0,0" 1 1 0)
Sebastian
Message 8 of 8
REALJOHNFROST
It works! Thanks so much!
