Small Modification in Lisp.
fkp7057
fkp7057
Hi All,
Need help to modify lsp program. this lsp is used to change block color.
this one work perfectly. but its not changing the color of dimension/leader.
is there any one who can modify as required ?
FKP
(defun c:blcc () (pl:block-color) (princ))
(defun c:encc () (pl:block-ent-color) (princ))
;;;get from Alaspher http://forum.dwg.ru/showthread.php?t=1036
;;; http://forum.dwg.ru/showpost.php?p=166220&postcount=18
(vl-load-com)
(defun pl:block-ent-color (/ adoc blocks color ent lays)
(setq adoc (vla-get-activedocument (vlax-get-acad-object))
lays (vla-get-layers adoc)
color (acad_colordlg 256)
(if color
(progn (setvar "errno" 0)
(vla-startundomark adoc)
(while (and (not (vl-catch-all-error-p
(setq ent (vl-catch-all-apply
(function nentsel)
'("\nSelect entity <Exit>:")
(/= 52 (getvar "errno"))
(if ent
(progn (setq ent (vlax-ename->vla-object (car ent))
lay (vla-item lays (vla-get-layer ent))
(if (= (vla-get-lock lay) :vlax-true)
(progn (setq layloc (cons lay layloc))
(vla-put-lock lay :vlax-false)
(vl-catch-all-apply (function vla-put-color) (list ent color))
(vla-regen adoc acallviewports)
(princ "\nNothing selection! Try again.")
(foreach i layloc (vla-put-lock i :vlax-true))
(vla-endundomark adoc)
(princ)
(defun pl:block-color (/ adoc blocks color ins lays)
blocks (vla-get-blocks adoc)
(if color
(setq ins (vl-catch-all-apply
(function entsel)
'("\nSelect block <Exit>:")
(if ins
(progn (setq ins (vlax-ename->vla-object (car ins)))
(if (= (vla-get-objectname ins) "AcDbBlockReference")
(if (vlax-property-available-p ins 'path)
(princ "\nThis is external reference! Try pick other.")
(progn (_pl:block-color blocks ins color lays)
(princ "\nThis isn't block! Try pick other.")
(princ)
(defun _pl:block-color (blocks ins color lays / lay layfrz layloc)
(vlax-for e (vla-item blocks (vla-get-name ins))
(setq lay (vla-item lays (vla-get-layer e)))
(if (= (vla-get-freeze lay) :vlax-true)
(progn (setq layfrz (cons lay layfrz)) (vla-put-freeze lay :vlax-false))
(progn (setq layloc (cons lay layloc)) (vla-put-lock lay :vlax-false))
(vl-catch-all-apply (function vla-put-color) (list e color))
(if (and (= (vla-get-objectname e) "AcDbBlockReference")
(not (vlax-property-available-p e 'path))
(_pl:block-color blocks e color lays)
(foreach i layfrz (vla-put-freeze i :vlax-true))
(progn
(princ "\BLCC - Changes color of the chosen blocks")
(princ "\nENCC - Changes color of the chosen objects (may be element of the block)")
(princ))
ВeekeeCZ
post a dwg sample file.
fkp7057
@ВeekeeCZ  Check sample block
