Small Modification in Lisp.
- Mute
- Permalink
- Report
Hi All,
Need help to modify lsp program. this lsp is used to change block color.
this one work perfectly. but its not changing the color of dimension/leader.
is there any one who can modify as required ?
FKP
(defun c:blcc () (pl:block-color) (princ)) (defun c:encc () (pl:block-ent-color) (princ)) ;;;get from Alaspher http://forum.dwg.ru/showthread.php?t=1036 ;;; http://forum.dwg.ru/showpost.php?p=166220&postcount=18 (vl-load-com) (defun pl:block-ent-color (/ adoc blocks color ent lays) (setq adoc (vla-get-activedocument (vlax-get-acad-object)) lays (vla-get-layers adoc) color (acad_colordlg 256) ) (if color (progn (setvar "errno" 0) (vla-startundomark adoc) (while (and (not (vl-catch-all-error-p (setq ent (vl-catch-all-apply (function nentsel) '("\nSelect entity <Exit>:") ) ) ) ) (/= 52 (getvar "errno")) ) (if ent (progn (setq ent (vlax-ename->vla-object (car ent)) lay (vla-item lays (vla-get-layer ent)) ) (if (= (vla-get-lock lay) :vlax-true) (progn (setq layloc (cons lay layloc)) (vla-put-lock lay :vlax-false) ) ) (vl-catch-all-apply (function vla-put-color) (list ent color)) (vla-regen adoc acallviewports) ) (princ "\nNothing selection! Try again.") ) ) (foreach i layloc (vla-put-lock i :vlax-true)) (vla-endundomark adoc) ) ) (princ) ) (defun pl:block-color (/ adoc blocks color ins lays) (setq adoc (vla-get-activedocument (vlax-get-acad-object)) blocks (vla-get-blocks adoc) lays (vla-get-layers adoc) color (acad_colordlg 256) ) (if color (progn (setvar "errno" 0) (vla-startundomark adoc) (while (and (not (vl-catch-all-error-p (setq ins (vl-catch-all-apply (function entsel) '("\nSelect block <Exit>:") ) ) ) ) (/= 52 (getvar "errno")) ) (if ins (progn (setq ins (vlax-ename->vla-object (car ins))) (if (= (vla-get-objectname ins) "AcDbBlockReference") (if (vlax-property-available-p ins 'path) (princ "\nThis is external reference! Try pick other.") (progn (_pl:block-color blocks ins color lays) (vla-regen adoc acallviewports) ) ) (princ "\nThis isn't block! Try pick other.") ) ) (princ "\nNothing selection! Try again.") ) ) (vla-endundomark adoc) ) ) (princ) ) (defun _pl:block-color (blocks ins color lays / lay layfrz layloc) (vlax-for e (vla-item blocks (vla-get-name ins)) (setq lay (vla-item lays (vla-get-layer e))) (if (= (vla-get-freeze lay) :vlax-true) (progn (setq layfrz (cons lay layfrz)) (vla-put-freeze lay :vlax-false)) ) (if (= (vla-get-lock lay) :vlax-true) (progn (setq layloc (cons lay layloc)) (vla-put-lock lay :vlax-false)) ) (vl-catch-all-apply (function vla-put-color) (list e color)) (if (and (= (vla-get-objectname e) "AcDbBlockReference") (not (vlax-property-available-p e 'path)) ) (_pl:block-color blocks e color lays) ) (foreach i layfrz (vla-put-freeze i :vlax-true)) (foreach i layloc (vla-put-lock i :vlax-true)) ) ) (progn (princ "\BLCC - Changes color of the chosen blocks") (princ "\nENCC - Changes color of the chosen objects (may be element of the block)") (princ))
