simple portion of LISP doesnt work in 2017 but did in 2014
dtiemeyer
Advisor Advisor
dtiemeyer
I have a lisp routine that does not complete correctly in 2017, but did work ok in 2014.   Basically its just a 'layer command' that does not function inside the routine.  Can anybody think of any environmental factors that may cause this? Either drawing variables or cad system/environment variables?
This is the part that does not work (but the command completes, there's no 'hard error):
(command ".-layer" "f" "e-fire-cvrg-n" "")
Earlier in the routine, this layer is generated (if it doesnt already exist) by a call to another LSP file, that's the only thing I can think of, but still, it all worked in 2014.
My other CAD is a Cadillac and I like to Revit to the Max!
Alexander.Rivilis
Try to change it with:
 (command-s "_.-layer" "_f" "e-fire-cvrg-n" "")
This pice of code work in my AutoCAD 2017 like a charm if e-fire-cvrg-n is not a current layer.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
dtiemeyer
Thank you Alexander, this did lead me to the solution.  It turns out I had to use the 'command-s' sequence in more than 1 location in the routine, but when I did, it all worked. Cheers.
Here's the final working bits (where 'prevlay' is defined earlier in the routine):
(command-s "_.-layer" "_set" prevlay "") ;Restore previous layer
(command-s "_.-layer" "f" "e-fire-cvrg-n" "")
