No objects exist in Selection Set - error: bad argument type: consp nil
RDunkley
RDunkley
I have a routine that I have been working on (cobbled together from various sources...) and have been getting this error "error: bad argument type: lselsetp nil" for the functions that have no objects in their selection set.
I am fairly new to lisp, what would be the best way to check if there are any objects in the selection set and if not end the function?
Regards.
Ross.
;Set elevations to 2 Decimal Places via Change in Point Label Style (EX_INVERT)
(vl-load-com)
(defun c:2DINV ( / Cpnt)
(SETQ CadApp (VLAX-GET-ACAD-OBJECT));Get AutoCAD Object
(setq C3dApp (vla-getinterfaceobject CadApp "AeccXUiLand.AeccApplication.11.0"));2017 C3D
(setq C3Ddoc (vla-get-activedocument C3dApp));Get Active Document
(setq ptlblstyles (vlax-get C3Ddoc 'pointlabelstyles));Get Point Styles
(setq style1 (vlax-get-property ptlblstyles 'item "ONK_(Elev) ONLY (INV) (2DP)"));get the Point Style
(mapcar 'vlax-release-object (list C3Ddoc C3dApp CadApp));release objects
;Select Points
(setq Slcsct (ssget "X" '((0 . "AECC_COGO_POINT")(8 . "EX_INVERT"))))
;Selection Length
(setq SlcLen (sslength Slcsct))
;Counter
(setq tn 0)
(repeat SlcLen
(setq tmpname (ssname Slcsct tn))
(setq Cpnt (vlax-ename->vla-object tmpname))
(vlax-put-property Cpnt 'LabelStyle style1 )
(setq tn ( + tn 1))
);repeat
);defun
(princ)
Currently using Civil 3D 2024 & AutoCAD 2025
Ranjit_Singh
I haven't tested but just localized the variables and added an if statement to check if the selection set has any objects. Give it a try
Spoiler
(vl-load-com)
(defun c:2DINV  (/ Cpnt CadApp C3dApp C3DDoc PTLBLSTYLES SLCLEN SLCSCT STYLE1 TMPNAME TN)
    (setq Slcsct (ssget "X" '((0 . "AECC_COGO_POINT") (8 . "EX_INVERT"))))
    (if Slcsct
        (progn (setq SlcLen (sslength Slcsct))
               (setq tn 0)
               (repeat SlcLen
                   (vlax-put-property Cpnt 'LabelStyle style1)
                   (setq tn (+ tn 1)))))
    (princ))
Kent1Cooper
Your Subject line and description don't agree about what the error message is, but assuming it's really the latter [about the selection]....
Because (ssget) returns nil if nothing is found, try this:
;Select Points
(if (setq Slcsct (ssget "X" '((0 . "AECC_COGO_POINT")(8 . "EX_INVERT"))))
  (progn ; then
;Selection Length
;Counter
    (setq tn 0)
    (repeat SlcLen
      (setq tn ( + tn 1))
    );repeat
  ); progn
); if
You can add an 'else' argument if you like, with a (prompt) or (alert) notifying the User that nothing qualifying was found.
Kent Cooper, AIA
