Simple Command Reactor
7 REPLIES 7
Message 1 of 8
658 Views, 7 Replies
I am a freebee to reactors. Could anybody help me write a simple reactor to command "Boundary"?
All I want to do is place a message in the command line: "Boundary finished running" after "Boundary" command finishes running.
Mike
7 REPLIES 7
Message 2 of 8
(or *CmdReactor*
(setq *CmdReactor*
(VLR-Command-Reactor nil '((:VLR-commandWillStart .
BrandName_CmdReactor:WillStart)
(:VLR-commandEnded .
BrandName_CmdReactor:Ended)
(:VLR-commandCancelled .
BrandName_CmdReactor:Canceled)
(defun BrandName_CmdReactor:WillStart (Reactor-Object Command-List) ;;;
Reactor Will Start
;;; Some events here. Since you don't have any hold it for future use
(princ)
(defun BrandName_CmdReactor:Ended (Reactor-Object Command-List) ;;; Reactor
Ended
(Boundary_finished_running Reactor-Object Command-List)
(princ)
(defun BrandName_CmdReactor:Canceled (Reactor-Object Command-List) ;;;
Reactor Canceled
(princ)
(defun Boundary_finished_running (Reactor-Object Command-List)
(and (member "BOUNDARY" Command-List)
(alert "Boundary finished running"))
(princ)
;_ MAKE SURE EXECUTE THIS IN THE END OF AUTOCAD SESSION
(defun BrandName_CleanReactors ()
(setq *CmdReactor* nil)
(mapcar 'VLR-Remove-All
'(:VLR-AcDb-Reactor :VLR-Editor-Reactor
:VLR-Linker-Reactor :VLR-Object-Reactor
:VLR-Command-Reactor :VLR-DeepClone-Reactor
:VLR-DocManager-Reactor :VLR-DWG-Reactor
:VLR-DXF-Reactor :VLR-Editor-Reactor
:VLR-Insert-Reactor :VLR-Linker-Reactor
:VLR-Lisp-Reactor :VLR-Miscellaneous-Reactor
:VLR-Mouse-Reactor :VLR-Object-Reactor
:VLR-SysVar-Reactor :VLR-Toolbar-Reactor
:VLR-Undo-Reactor :VLR-Wblock-Reactor
:VLR-Window-Reactor :VLR-XREF-Reactor
wrote in message news:4813841@discussion.autodesk.com...
> Hi,
> Thanks,
> Mike
Message 3 of 8
Gaspar,
Thanks a lot! That works great. Do reactors work only with AutoCAD commands or could be used for lisp routines as well?
Mike
Message 4 of 8
Hi Mike,
If you wanted to do something associated with running a program (written in
any language - not just lisp) why not write it into the program?
It would seem adding a reactor into the program would be like saying:
Am I running ?
If I am I must do something ?
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:4814228@discussion.autodesk.com...
> Gaspar,
> Thanks,
> Mike
Message 5 of 8
When a command (sendcommand) is sent to AutoCAD from a dll, the dll is not going to wait for the command to stop running. They are two different processes. In fact, the dll will finish running before a command in AutoCAD is executed. What if I wanted to use the results of sendcommand later in the dll code? The only way I can do that is to know when the sendcommand is finished executing and then continie running my code.
That is basically why I need to know how to use reactors. Message was edited by: mgrigoriev
Message 6 of 8
Here is a little sample about the lisp routines....
(defun commandwillstart (reactor params / acad_obj)
(if (= (car params) "EATTEDIT")
(vla-eval (setq acad_obj (vlax-get-acad-object))
(strcat "Sendkeys \"{ESC}\""))))
(defun lispwillstart (reactor params / acad_obj)
(if (= (car params) "(C:FC)")
(if (not cmd_cancel_editor_reactor)
(setq cmd_cancel_editor_reactor
(vlr-editor-reactor
nil
'((:vlr-commandwillstart . commandwillstart)))))
(if (not cmd_cancel_lsp_reactor)
(setq cmd_cancel_lsp_reactor
(vlr-lisp-reactor
nil
'((:vlr-lispwillstart . lispwillstart)))))
Message 7 of 8
I am sorry, you posted some code after MAKE SURE EXECUTE THIS IN THE END OF AUTOCAD SESSION. Where should I put this code?
Message 8 of 8
If I was writing a program that's worth protecting I wouldn't be using
Sendcommand - or if it was essential - I'd leave it till last in the
execution chain.
Also, although I haven't installed 2006 yet, I heard rumours Autodesk have
modified it to allow code with sendcommand to end before moving on. Check
the documentation when you get it.
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:4815000@discussion.autodesk.com...
AutoCAD Inside the Factory
