Silent Pedit
Silent Pedit
hmsilva
Mentor Mentor
Message 1 of 52
Silent Pedit
hmsilva
I'm trying to execute a pedit command in a lisp routine, without echoing, with no luck...
cmdecho and nomutt dont resolve my problem...
Can somebody points me the right way please...
Any help would be most appreciated.
Cheers
Henrique
Replies (51)
Message 2 of 52
Mr. Silva
First of all you have to get an idea of how Pedit command works.
Message 3 of 52
which version of acad do you use?
(command "_pedit" w "_f" "")
is a silent command in acad 2004
where (setq w (car (entsel "your polyline")))
CMDECHO 0
EXPERT 1
dont forget the (princ) at the end of the
(defun
(princ)
> Cheers
> Henrique
Message 4 of 52
hmsilva
Hi gert
thanks for your reply, I use A2K8 and I am doing lots of pedit's
inside my code, and each time I do one I get's the echo message ...
I have the CMDECHO set to 0, and EXPERT to zero too.
I'll try to set to 1.
Thanks again
Henrique
Message 5 of 52
hmsilva
CMDECHO 0
EXPERT 1
no luck...
Thanks anyway…
Henrique
Message 6 of 52
make a screenshot of the message you get and post it
hmsilva wrote:
> Hi gert
> Thanks again
> Henrique
Message 7 of 52
hmsilva
Hi gert
It's done..
Setting NOMUTT to 1
Thanks again...
Cheers
Henrique
Message 8 of 52
Hi hmsilva,
How about my code maybe can help you
[code]
; arp is stand for As Replace Pedit
; Design by : Adesu
; Email : mteybid@yuasabattery.co.id
; Homepage : http://www.yuasa-battery.co.id
; Create : 08 June 2007
; Program no.: 0592/06/2007
; Edit by :
; Idea from : VVA
(defun c:arp (/ ss)
(prompt "\nSelect alls object line")
(while
(not ss)
(setq ss (ssget))
) ; while
(if
ss
(progn
(if
(and (getvar "peditaccept")(= (getvar "peditaccept") 1))
(command "_pedit" "_m" ss "" "_j" 0 "")
(command "_pedit" "_m" ss "" "_y" "_j" 0 ""))
) ; progn
) ; if
(princ)
) ; defun
[/code]
wrote in message news:5694569@discussion.autodesk.com...
with no luck...
Cheers
Henrique
Message 9 of 52
hmsilva
Hi Adesu
Thanks for your reply, my code is done..
My problem was just removing the echo from the command line and I solve it seting the NOMUTT sysvar to 1.
My code is an automatic Pedit, by selecting one; line, arc or poly, it scans the endpoints and perform a pedit until there is no more elements to join...
Thanks again
Henrique
Message 10 of 52
Ktelang
Hello Mr Silva,
Can you please share the code.
I will be performing similar 1000s  of
pedits. I think your last post talks about exactly what
I want.
If I am not asking too much and if its fine with
you I will appreciate your help related to same
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Message 11 of 52
Kent1Cooper
That description sounds like a lot more work than necessary.  Just do this:
(defun C:PEJA (/ peac cmde); = Polyline Edit: Join All
  (setq peac (getvar 'peditaccept))
  (setvar 'peditaccept 1)
  (setq cmde (getvar 'cmdecho))
  (setvar 'cmdecho 0)
  (command "_.pedit" pause "_join" "_all" "" "")
  (setvar 'peditaccept peac)
  (setvar 'cmdecho cmde)
  (princ)
Yes, in the object selection it will find everything in the current space, but it will ignore anything that doesn't connect end-to-end with the selected object, and anything of the wrong object type, and join everything it can.  No scanning of endpoints is needed.
For me back in AutoCAD 2004, setting CMDECHO to 0 does suppress echoing to the Command: line [otherwise I wouldn't have included it here], so the problem in the original post doesn't exist.  But even if that's changed in newer versions, the Join All approach means there isn't very much echoed there, anyway [certainly nothing like what would be in the approach quoted above], no matter how many things are joined.
It could be made more sophisticated, such as by restricting object selection to only Peditable types, if desired.
Kent Cooper, AIA
Message 12 of 52
TomBeauford
Simular, but if you select more than one line this one will just join the selected segments:
(defun c:pljoin (/ cmdecho peditaccept ss ss1 lent)
  (setq cmdecho (getvar "cmdecho")
        peditaccept (getvar "peditaccept")
        lent (entlast)
  (setvar "cmdecho" 0)
  (setvar "peditaccept" 1)
  (princ "\nSelect object to join: ")
  (setq ss (ssget '((0 . "LINE,ARC,POLYLINE,LWPOLYLINE"))))
  (if (/= ss nil)
      (progn
	(if (= (sslength ss) 1)
          (progn
            (sssetfirst nil ss)
            (command "_.pedit" "_J" (ssget "X" '((0 . "LINE,ARC,POLYLINE,LWPOLYLINE"))) "" "")
          (command "_.pedit" "_M" ss "" "_J" "0.0" "")
  (setvar "cmdecho" cmdecho)
  (setvar "peditaccept" peditaccept)
  (princ)
 I have it in my Edit Shortcut menu.  I used to use the Macro: ^C^C^P(ssget);pedit;m;p;;j;0.0;;
I wrote the code because I'll often join a few lines and didn't want to have any extra joined in.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 13 of 52
Ktelang
Thanks for that perfect
Message 14 of 52
greg_battin
Hey Kent,
this routine (EJA) is awesome. I use it almost everyday.
Thank you
~Greg
Message 15 of 52
ojuris
This one  (ljoin) from beaufordt  is perfect!
THANKS
Juris
Message 16 of 52
Kent1Cooper
        lent (entlast)
  (if (/= ss nil)
      (progn
          (progn
            (sssetfirst nil ss)
  (princ)
I like the automatic handling of multiple joins if multiple things are selected, but join-everything-possible if only one is.  For my own use, I made a streamlined version [removed unused lent variable and took unused ss1 out of local variables list, removed two unnecessary (progn)'s & an (sssetfirst), simplified (ssget) filtering and join-all-possible object selection, made prompt more descriptive, shortened command name and some variable names, consolidated (setq)'s, repositioned (setvar)'s to eliminate need for error handling to reset if cancelled in selection].
;; PolylineJoin.lsp [command name: PJ]
;; Based on c:pljoin by beaufordt from AutoCAD Customization Discussion Group
;; Streamlined by Kent Cooper, June 2011
(defun C:PJ (/ cmde peac ss); = Polyline Join
  (princ "\nTo join touching objects into Polyline(s) [pick 1 to join all possible objects to it],")
  (setq
    ss (ssget '((0 . "LINE,ARC,*POLYLINE")))
  ); end setq
  (setvar 'cmdecho 0)
  (if ss
      (command "_.pedit" ss "_join" "_all" "" ""); then
      (command "_.pedit" "_multiple" ss "" "_join" "0.0" ""); else
    ); end inner if
  ); end outer if
  (princ)
); end defun
Kent Cooper, AIA
Message 17 of 52
Kent1Cooper
An update of the PolylineJoin.lsp routine [PJ command], with added error handling, rejection of selection 3D Polylines [which can't be joined] and 2D "heavy" Polylines that are spline- or fit-curved [because joining them to other things removes their curvature], preservation of selected Lines/Arcs that don't have contiguous objects to join to as Lines/Arcs rather than single-segment Polylines, and a few other small refinements.
Also posted on this later thread:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Lines-to-pline-in-one-step/m-p/353442...
where the same subject came up again.
Kent Cooper, AIA
Message 18 of 52
danielrT8PHL
The polylinejoin.lsp doesn't seem to work on ACAD2002. This is the error message I receive:
Error: AutoCAD variable setting rejected: PEDITACCEPT 1; error: An error has
occurred inside the *error* functionAutoCAD variable setting rejected:
PEDITACCEPT nil
I know I'm using an ancient release of ACAD, but is there a way to make this work??
Message 19 of 52
Kent1Cooper
@danielrT8PHL wrote:
The polylinejoin.lsp doesn't seem to work on ACAD2002. ….
Does the PEDITACCEPT variable exist at all in 2002?  If not, does it work as if in later versions it was set to 1?  That is, in PEDIT, if you select a Line or Arc that isn't already a Polyline, does it just go ahead without challenging you?  If that's the case, the routine could be "fixed" to remove all references to it, i.e. remove these lines:
  (setvar 'peditaccept peac) ;; in two places
and take 'peac' out of the localized variables list at the top.
Kent Cooper, AIA
Message 20 of 52
john.uhden
What do you want to do?
Maybe my VEDIT routine would be helpful.
John F. Uhden
