Show prompt if any xrefs exist
Message 1 of 8
Happy New Year to everyone Smiley Happy
Im working on a routine that suppose to run without any xrefs in the drawing. Need help on checking if theres any xref exist in the drawing.
if xref exist = show message
if no xref found = continue with routine
Thanks in advance! Smiley Happy
Replies (7)
Message 2 of 8
hmsilva
One way
  (vl-load-com)
  (vlax-For blk
		(vla-Get-Blocks
		  (vla-Get-ActiveDocument (vlax-Get-Acad-Object))
    (if	(= (vla-Get-IsXref blk) :vlax-True)
      (setq xr T)
  (if xr
      (alert "if xref exist = show message")
    (progn
      ;; if no xref found = continue with routine
Henrique
Message 3 of 8
Thanks for the reply Henrique!
the code works as expected but when I open a dwg with xref and detach it then run the routine, it still says theres xref in the drawing.
Edit:
I tried to close and reopen and it worked fine. I guess this can work.
Thanks Henrique!Smiley Happy
Message 4 of 8
hmsilva
Edit:
You're welcome, JCprog
You'll have to declare 'xr' as a local variable, and the test should work as expected without closing/reopen de dwg...
Henrique
Message 5 of 8
nice! I learn something everyday 🙂 works perfect! Thanks again!
Message 6 of 8
hmsilva
Glad I could help
Henrique
Message 7 of 8
Lee_Mac
Another, returns T if one or more xrefs are defined in the active drawing:
(defun xrexists ( / def flg )
    (while
        (and
            (setq def (tblnext "block" (null def)))
            (not (setq flg (= 4 (logand 4 (cdr (assoc 70 def))))))
    flg
Message 8 of 8
Thanks for the code Lee! you guys are awesome! 🙂
