Finding a word(s) and putting a circle around it?
johnw
Message 1 of 15
johnw
I work with a lot of plan options and I was trying to find a routine that would find any word "opt", "Opt", or "REFER" in a cad drawing (including these words INSIDE a block), then place a 2'-0" diameter circle around the word(s) the command finds on Layer 0, color 60.
If anyone has an idea of how to do this or where I could find a routine that would acccomplish this, or start me on my way, I would appreciate it.
Thank you,
John W.
Replies (14)
Message 2 of 15
Lee_Mac
Hi John,
Here's a quick draft:
(defun c:cfind ( / center cnt lst mat rad str tmp )
    (setq rad 12.0 ;; Circle radius
          cnt 0
    (defun center ( obj / llp urp )
        (if (and (vlax-method-applicable-p obj 'getboundingbox)
                 (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list obj 'llp 'urp))))
            (apply 'mapcar
                (cons '(lambda ( a b ) (/ (+ a b) 2.0))
                    (mapcar 'vlax-safearray->list (list llp urp))
           '(0.0 0.0)
    (if (/= "" (setq str (strcase (getstring t "\nSpecify word to find: "))))
        (progn
            (vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
                (if (= :vlax-false (vla-get-islayout blk))
                    (vlax-for obj blk
                        (cond
                            (   (= :vlax-false (vla-get-visible obj)))
                            (   (wcmatch (vla-get-objectname obj) "AcDb*Text")
                                (if (= (strcase (vla-get-textstring obj)) str)
                                    (setq tmp (cons (center obj) tmp))
                            (   (and (= "AcDbBlockReference" (vla-get-objectname obj))
                                     (= :vlax-true (vla-get-hasattributes obj))
                                (foreach att (vlax-invoke obj 'getattributes)
                                    (if (= (strcase (vla-get-textstring att)) str)
                (if tmp
                    (setq lst (cons (cons (vla-get-name blk) tmp) lst)
                          tmp nil
                (if (= :vlax-true (vla-get-islayout blk))
                    (vlax-for obj blk
                        (cond
                                    (progn
                                        (vla-addcircle blk (vlax-3D-point (center obj)) rad)
                                        (setq cnt (1+ cnt))
                            (   (= "AcDbBlockReference" (vla-get-objectname obj))
                                (if (= :vlax-true (vla-get-hasattributes obj))
                                            (progn
                                                (setq cnt (1+ cnt))
                                (if (setq tmp (cdr (assoc (vla-get-name obj) lst)))
                                    (progn
                                        (setq mat (refgeom (vlax-vla-object->ename obj)))
                                        (foreach ins tmp
                                            (vla-addcircle blk (vlax-3D-point (mapcar '+ (mxv (car mat) ins) (cadr mat))) rad)
                                            (setq cnt (1+ cnt))
            (cond
                (   (= 1 cnt)
                    (princ "\nOne match found.")
                (   (= 0 cnt)
                    (princ "\nNo matches found.")
                (   (princ (strcat "\n" (itoa cnt) " matches found.")))
    (princ)
;; RefGeom (gile)
;; Returns a list whose first item is a 3x3 transformation matrix and
;; second item the object insertion point in its parent (xref, block or space)
(defun refgeom ( ent / ang enx mat ocs )
    (setq enx (entget ent)
          ang (cdr (assoc 050 enx))
          ocs (cdr (assoc 210 enx))
    (list
        (setq mat
            (mxm
                (mapcar '(lambda ( v ) (trans v 0 ocs t))
                        (1.0 0.0 0.0)
                        (0.0 1.0 0.0)
                        (0.0 0.0 1.0)
                (mxm
                    (list
                        (list (cos ang) (- (sin ang)) 0.0)
                        (list (sin ang) (cos ang)     0.0)
                       '(0.0 0.0 1.0)
                    (list
                        (list (cdr (assoc 41 enx)) 0.0 0.0)
                        (list 0.0 (cdr (assoc 42 enx)) 0.0)
                        (list 0.0 0.0 (cdr (assoc 43 enx)))
        (mapcar '- (trans (cdr (assoc 10 enx)) ocs 0)
            (mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))))
;; Matrix Transpose  -  Doug Wilson
;; Args: m - nxn matrix
(defun trp ( m )
    (apply 'mapcar (cons 'list m))
;; Matrix x Matrix  -  Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
    ((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Matrix x Vector  -  Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
    (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
(vl-load-com) (princ)
The above is not compatible with nested blocks however.
Lee
Message 3 of 15
johnw
Wow Thanks Lee, that is some fast code writing! I appreciate the effort for sure! I tried running it in a drawing and received a "malformed list" return. I looked through it but I don't have any visual Lisp editor and finding where the issue is would be over my head. Thank you again for helping me with this!!
John W.
Message 4 of 15
Lee_Mac
You're welcome John.
A 'malformed list' error would indicate a missing closing parenthesis ")"; since the code performs successfully in my testing, are you certain that you have copied the code correctly?
Lee
Message 5 of 15
johnw
After copy/pasting from this site the routine worked! I originally copied from my email alert and routine was almost on one line once I pasted to Notepad. LOL.
Thanks for whipping this one out! Pure genious!
John W.
Message 6 of 15
Lee_Mac
Excellent! - I'm delighted to hear that the code is working well.
Message 7 of 15
johnw
Hi Lee,
When you have a moment, can you modify the code so it can find a word that is in part of a sentence. I.e. I want to put a circle around the word "OPT." but most of these words are in a sentence like "OPT. SERV. DOOR" or "OPT. LAUNDRY TUB" etc.
John W.
PS - I sent you an email yesterday with a programming request.
Message 8 of 15
Lee_Mac
This would not be possible to achieve, sorry.
Received, thank you.
Message 9 of 15
Lee_Mac
To clarify my response - circling the specific word within the sentence would not be possible, but simply detecting the word and circling the entire text object would certainly be possible by switching the "=" operator with the wcmatch function and supplying the program with a wildcard pattern, e.g. "*OPT*".
Lee
Message 10 of 15
johnw
Lee, how would I show the "wcmatch" in the routine? I've never used this and wouldn't know how to revise your code.
John
Message 11 of 15
Lee_Mac
Hi John,
Try the following:
          cnt 0
            (apply 'mapcar
           '(0.0 0.0)
        (progn
                    (vlax-for obj blk
                        (cond
                                (if (wcmatch (strcase (vla-get-textstring obj)) str)
                                    (if (wcmatch (strcase (vla-get-textstring att)) str)
                (if tmp
                          tmp nil
                    (vlax-for obj blk
                        (cond
                                    (progn
                                        (setq cnt (1+ cnt))
                                            (progn
                                                (setq cnt (1+ cnt))
                                    (progn
                                        (foreach ins tmp
                                            (setq cnt (1+ cnt))
            (cond
                (   (= 1 cnt)
                (   (= 0 cnt)
    (princ)
;; RefGeom (gile)
    (list
        (setq mat
            (mxm
                        (1.0 0.0 0.0)
                        (0.0 1.0 0.0)
                        (0.0 0.0 1.0)
                (mxm
                    (list
                       '(0.0 0.0 1.0)
                    (list
(defun trp ( m )
(defun mxm ( m n )
(defun mxv ( m v )
The above will allow you to specify wildcard patterns, e.g. *OPT*
Message 12 of 15
johnw
Thanks Lee. The wildcard addition seems to work. Thanks for the extra work on this one!
John W.
Message 13 of 15
Lee_Mac
You're welcome John, no problem.
Lee
Message 14 of 15
johnw
Lee, will this command also find words inside a "block"?
Message 15 of 15
Lee_Mac
Yes, but not within nested blocks (though, with some time it could be made to do so)
