show line direction
show line direction
Message 1 of 32
show line direction
Hi everyone,
can you help with a lisp that shows the direction of selected lines,
like this lisp for polyline:
https://autocadtips1.com/2014/06/24/autolisp-polyline-direction-preview/#:~:text=You%20simply%20run%...
and also ask for lines to change direction if needed.
It would be very helpfull.
Thank you
Eyal.
Accepted solutions (3)
Replies (31)
Message 21 of 32
THANK YOU @Moshe-A ,
Thats great!
Eyal
Message 22 of 32
Moshe-A
@Anonymous  hi,
Thats great!
Eyal
here is an improvement \ new cool option 😀  (lisp file attached)
Aside to Show\Reverse options you now have a new Flip option which flips the arrow side. each line now hold in its database XDATA (eXtended Data) that denote if the line is in its origin\reversed direction and if the arrows are in the left\right side of the line. so now the reverse option does not flip the arrows side.
this cool feature could not be made without 2 beautiful functions [(MeGetXdata) and (MeSetXdata)] by MENZI ENGINEERING GmbH, Switzerland.  so the credits goes to MENZI.
Another feature to note is while you are still in the LID selecting lines,  you can use the Previous option to quickly select the same lines.
enjoy
Moshe
Message 23 of 32
Moshe-A
@Anonymous
Made more fine tuning and this is the final version 😀
also a new prompt to let you choose a new color for the arrows.
enjoy
Moshe
Message 24 of 32
Thank you @Moshe-A ,
it is great,
Can I ask for one more adaptation for this lisp,
If you can, I want to enable the "S" for the show, and "R" for reverse, and "F" for flip to be clickable, like the other commands in Autocad, it saves time instead of typing.
Just if it is no trouble,
Thank you
Eyal.
Message 25 of 32
Moshe-A
@Anonymous ,
here you go
Message 26 of 32
Hi @Moshe-A ,
Thank you very much!!!
you are a champ!
it will be very useful for me,
Good day!
Eyal
Message 27 of 32
Sea-Haven
Just a suggestion for pick color use (setq ask  (acad_colordlg clr)) where clr is a default color number you set.
Re the choices your welcome to use this
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (not but)(setq but 1))
(setq ans  (ah:butts but "V"   '("Please choose " "Show" "Reverse" "Flip")))
Message 28 of 32
Hi @Sea-Haven ,
It looks awesome to have it on the table, can you please add this to @Moshe-A 's lisp?
the last one in this post.
Thank you,
Eyal
Message 29 of 32
Moshe-A
@Sea-Haven ,
Thanks for the advice but in this case i think, a dialog is not preferrable cause at the command line it works quickest.
Moshe
Message 30 of 32
Hamza.itani
Please, can this be modified to work with polylines?
Message 31 of 32
Kent1Cooper
@Hamza.itani wrote:
....can this be modified to work with polylines?
Have you followed the link in Message 1?  It's supposedly [I haven't looked] something that shows the direction of Polylines.
Kent Cooper, AIA
Message 32 of 32
Hamza.itani
Yes, I have. But the original lisp lacks the ability to select multiple polylines at once plus reversing on the fly, which are useful.
