show length\tag label of polyline
Nicht anwendbar
4.970Aufrufe
35Antworten
Nachricht 1 von 36
Nicht anwendbar
im drawing water plan with polyline
each pipe (PEX) get is own polyline
im looking for a lisp or something else that will show the total length of each polyline +1.5 meter (for the vertical rise)
it is possible?
0 „Gefällt mir“-Angaben
Akzeptierte Lösungen (1)
4.971Aufrufe
35Antworten
Antworten (35)
Nachricht 2 von 36
hak_vz
@Anonymous
Always add sample drawing and lots of details about how you want your problem solved.
In this case how you want pipes lengths to be shown i.e written over a pipe, alert box or else?
Miljenko Hatlak
Nachricht 3 von 36
hak_vz
Since you didn't answered on time, here is something to play with.
(defun c:pipe_lenght ( / vertical_rise get_length pick_line e l *error*)
(defun *error* ( msg )
	(if (not (member msg '("Function cancelled" "quit / exit abort")))
		(princ (strcat "\nError: " msg))
	(princ)
(setq vertical_rise (getreal "\nVertical rise to add to pipe length [0]> "))
(if (not vertical_rise) (setq vertical_rise 0))
(defun get_length (e)
(cond ((and e (= (type e) 'ENAME)) (setq e (vlax-ename->vla-object e))))
(cond ((and e (vlax-property-available-p e 'Length)) (vlax-get e 'Length)))
(defun pick_line( / ss)
	(setq e (car(entsel "\nSelect pipe >")))
	(if (and (not e) (= (getvar 'Errno) 7)) (pick_line) e)
(while (setq l (get_length (pick_line))) (princ (strcat "\n" (rtos (+ l vertical_rise) 2 2))))
(princ)
Miljenko Hatlak
Nachricht 4 von 36
Kent1Cooper
As a start, >LabelLengths.lsp< may do what you want.  If it does for the actual lengths, it can easily be modified to add a fudge factor.
Kent Cooper, AIA
Nachricht 5 von 36
3wood
You can do it in 2 steps.
Step 1, add length tag to polylines. You can try ADDLINES.
Step 2, modify the tags in  Step 1 and add 1.5m to each tag with ALTEXT.
Nachricht 6 von 36
Nicht anwendbar
sorry for the delay
I want alert box
I need the length to be an Integer or number and a half (exp- 1m, 1.5m, 2m, 2.5m etc...)
Nachricht 7 von 36
pbejse
is the tag connected to the polyline in anyway?
Nachricht 8 von 36
Nicht anwendbar
it's not necessary but it will be nice.
Nachricht 9 von 36
hak_vz
@Anonymous wrote:
sorry for the delay
I want alert box
(defun c:pipe_lenght ( / vertical_rise get_length pick_line a b d e l *error*)
	(princ)
(setq d (atof(rtos (+ l vertical_rise) 2 2)))
(setq a (fix d) b (atoi(rtos (* 100 (- d a)) 2 1)))
(cond
	((<= b 25) (setq b 0))
	((and (> b 25)(<= b 75)) (setq b 5))
	((> b 75) (setq b 10))
(alert (strcat "\nPipe length = " (rtos (+ a (/ b 10.0)) 2 1)))
(prin
@Anonymous  I hope this is what you asked for. If it works for you, accept this tread as a solution.
Miljenko Hatlak
Nachricht 10 von 36
pbejse
I'm not suggesting anything @Anonymous , its actually a question for you as per you request below.
I assumed the "water tag" block is the tag, the existing blocks already shows a length and a tag name.
Are you wanting to get the total of  all same tag values? which in effect does not involve selecting any of the polylines  under "water" layer?
or are you  wanting the user to select a polyline then assign the values to the "water tag" block?
Please post an example of the result.
Nachricht 11 von 36
Nicht anwendbar
i got this error when loading the lisp
Command: _appload pipelength.lsp successfully loaded.
Command: ; error: malformed list on input
Nachricht 12 von 36
hak_vz
Try now
	(princ)
	(if (and (not e) (= (getvar 'Errno) 7)) (pick_line))
	e
(cond
(princ)
Miljenko Hatlak
Nachricht 13 von 36
Nicht anwendbar
I did put the length and the tag number manually in the water tag
each polyline represents pipe segment (hot/cold)
I need to know the length of each pipe - for example the length of the cold water pipe from the water cabinet to the shower is 8 meter.
Nachricht 14 von 36
Nicht anwendbar
that work!
now how can i take this lisp and make him put the result into water tag block?
Nachricht 15 von 36
hak_vz
	(princ)
	e
(while (setq l (* 0.01 (get_length (pick_line))))
(cond
(command "_.insert" "water tag")
(princ)
Miljenko Hatlak
Nachricht 16 von 36
pbejse
@Anonymous wrote:
that work!
That is exactly what i'm referring to @Anonymous
(defun c:Demo ( /  _pline _Tag  attbv lenTag nosTag len)
(setq riser (cond
    ((getreal (strcat "\nChoose a Number <" (rtos (setq riser
              (cond ( riser ) ( 2.50 )) ) 2 2
    ( riser )))
(setq _tagNos (cond
    ((getint (strcat "\nEnter TAG number <"
		     (itoa (setq _tagNos (cond ( _tagNos ) ( 1 ))))
    ( _tagNos )))
(if
	(and
	  (setq _pline (ssget "_+.:S:E" '((0 . "LWPOLYLINE")(8 . "water"))))
	  (setq _Tag (ssget "_+.:S:E" '((0 . "INSERT")(2 . "main supply tag,water*tag"))))
	  (progn
	      (setq len (rtos
			  (* (vlax-get (vlax-ename->vla-object (ssname _pline 0)) 'Length) 0.01) 2 0))
	      (setq  attbv	(mapcar
			  '(lambda (at)
			     (list (Vla-get-tagstring at) at)
			  (vlax-invoke
			    (vlax-ename->vla-object (ssname _Tag 0)) 'GetAttributes
	    (alert (strcat "\nWater pipe length = " (setq len (rtos (+ (atoi len) riser) 2 1))))
	    (cond
	      ((null attbv)	)
	      ((and
			(setq lenTag (assoc "LENGTH" attbv))
			(setq nosTag (assoc "NO." attbv)))
			(vla-put-textstring (cadr lenTag) len)
	                (vla-put-textstring (cadr nosTag)(itoa _tagNos))
	      ( lenTag
	      	(vla-put-textstring (cadr lenTag) len )
	    (setq _tagNos (1+  _tagNos))
  (princ)
HTH
Nachricht 17 von 36
Nicht anwendbar
why it doesn't show the tag at the end?
Command: DEMO
Choose a Number <1>:
Enter TAG number <1>: 5
Select objects:
Command:
Nachricht 18 von 36
Nicht anwendbar
still need to write manually the length
can't it take the length from the command and put it automatically in this window
Command: PIPE_LENGHT
Vertical rise to add to pipe length [0]> 1500
Select pipe >_.insert Enter block name or [?] <A$Cf59cb81f>: water tag
Units: Unitless Conversion: 1.0
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate/Explode/REpeat]:
Error: bad argument type: numberp: nilSpecify insertion point or [Basepoint/Scale/X/Y/Z/Rotate/Explode/REpeat]:
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>:
Enter Y scale factor <use X scale factor>: 1
Specify rotation angle <0>:
Nachricht 19 von 36
hak_vz
	(setvar 'attdia 1)
	(setvar 'cmdecho 0)
	(princ)
	e
(setvar 'attdia 0)
(setvar 'cmdecho 0)
(cond
(setq d (atof(rtos (+ a (/ b 10.0)) 2 1)))
;(alert (strcat "\nPipe length = " d))
(setq pt (getpoint "\nPick water tag insertion point >"))
(setq no (getint "\nTag number >"))
(command "_.insert" "water tag" pt 0.1 0.1 0 no d )
(setvar 'attdia 1)
(setvar 'cmdecho 1)
(princ)
Try this version that directly places "water tag" block without showing alert. If you want to show alert then delete ;
infront (alert .....)
Miljenko Hatlak
Nachricht 20 von 36
pbejse
Command: DEMO
Select objects:
Command:
Its' my bad, I mislabelled the prompt. it should say
(setq riser (cond
    ((getreal (strcat "\nEnter vertical riser height <" (rtos (setq riser
    ( riser )))
Also, there are missing prompt that the user should be able to idenftify what to select
(defun c:WaterLine( /  _pline _Tag  attbv lenTag nosTag len)
(setq riser (cond
    ( riser )))
(setq _tagNos (cond
    ( _tagNos )))
(if
	(and
	  (princ "\nSelect Polyline")
	  (princ "\nSelect tag block")
	  (progn
	      (setq len (rtos
	      (setq  attbv	(mapcar
			  '(lambda (at)
			  (vlax-invoke
	    (cond
	      ((null attbv)	)
	      ((and
	      ( lenTag
  (princ)
How it works:
command: waterline
Enter vertical riser height <2.50>: [ either enter a new value of accept the default ]
Enter TAG number <4>:  [ either enter a new value of accept the default ]
Select Polyline <-- was mising before
Select objects:
Select tag block <-- was mising before
Now, keep in mind that on your drawing, you have 3 different tags,
  • "water tag", <-- this has two attributes  ( "LENGTH" "NO." )
  • "water heater tag" and  "main supply tag" both has only one attribute   ( "LENGTH" )
We can modify the program to prompt the user to insert a block for a spefic tag,  will that work for you?
command: WHT for "water heater tag"
command: MST "main supply tag"
command: Waterline for "water tag"
