Sheet List Table
Sheet List Table
Sheet List Table
Hello!
I have been exploring the use of the Sheet Set Manager and it's great use of fields. I am trying to get the most out of the Sheet List Table for our custom drawing index table for each of our drawing sets. I only need the drawing title and drawing number, but I have three issues that I'm hoping can be solved. Without manual editing every time I do a Sheet List Table.
1. I'm wondering if it's possible to omit the Title row from the table when inserting the sheet list table. I use the Data and Header, but not the Title
2. I'm wondering if it's possible to make sure that each row has a height of only one line. It is likely that every one of my drawing sets will have a sheet title that ends up wrapping to the next line in the cell and throwing off the row height, which forces me to edit the column width and the specific row heights.
3. And finally, I'm wondering if I can change a alignment of one columns cells in the Data cells to Middle Center but have the other column of Data cells to stay Middle Left.
I wonder if there is a solution with AUTOLISP or maybe customization in AutoCAD. Help with any of these would be much appreciated!
Michael
pbejse
Post a cad drawing showing the current table as you described on your message. and one that shows your
preferred output.
Throw in a sample DST file to go with that too.
Thanks for the reply. I've attached a drawing with the front sheet (#1) containing both the default table outcome and the preferred outcome after I've adjusted it.
Michael
The one I marked "DEFAULT" is the unadjusted outcome when I simply "Insert Sheet List Table" and place it in the drawing.
maratovich
Give an example table.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
I linked my drawing file with the tables. The one that is created when I use "Insert Sheet List Table" and the finished product after adjustments. They are both Sheet List Tables. I also attached the DST file.
