Shared Custom Tool Palette Slow Loading
ArchD
ArchD
I am creating a shared tool palette on a network server. When switching between tabs it takes a few minutes to load for the first time in a session. I have seen multiple "solutions" to this problem on the internet but have not had any luck with it.
I can create them initially while pathed to nothing but the network location, but when I do that I lose all of my default ACAD tool palette groups which I would like to keep. So basically I path to the network, create the palette, make it read only, repath my default palette location and my network location second. It seems to work fine for a little while until I need to make changes to the shared palette.
Does anyone have a solution to this? It has been an issue for years and I can not see why AutoDESK does not address it.
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
wispoxy
I'll run some tests. Give me until (mid-day) Wednesday, the 24th of August. By-the-way, what happens when you take it off read only? Is it faster?
