Setting a Name Page Setup to the current layout
RockyBrown4134
Message 1 of 9
RockyBrown4134
Is there a way to set a page layout to current in Lisp?
I have six named page layouts and I want to be able to set them when I call in my paper border, based on the sheet size. I have look on the discussion board and have not seen anything, probably because I have never had to use page layouts before.
If there are any suggestions, setting a variable, invoking the command on the command line, or just any better way, please feel free post.
I appreciate all the education in the area.
Thanks.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
Replies (8)
Message 2 of 9
Jonathan3891
Take a look at this;
(defun c:layName (/ bNme aNme lay ss att e)
  (vl-load-com)
  (setq bNme "TITLEBLOCK" aNme "ATT")
  (vlax-for lay (vla-get-layouts
                  (vla-get-ActiveDocument (vlax-get-acad-object)))
    (if (and (not (eq "MODEL" (strcase (vla-get-Name lay))))
             (setq ss  (ssget "_X" (list (cons 0 "INSERT")
                                         (cons 2 bNme)
                                         (cons 66 1)
                                         (cons 410 (vla-get-Name lay))))))
        (foreach att  (vlax-invoke
                        (vlax-ename->vla-object (ssname ss 0)) 'GetAttributes)
          (if (apply 'eq (mapcar 'strcase (list aNme (vla-get-TagString att))))
            (if (vl-catch-all-error-p
                  (setq e (vl-catch-all-apply 'vla-put-Name
                            (list lay (vla-get-TextString att)))))
              (princ (strcat "\n** Error: " (vl-catch-all-error-message e) " **")))))))
  (princ))
Jonathan Norton
Blog | Linkedin
Message 3 of 9
RockyBrown4134
Thanks. I'll give this a try.
The is a new piece to the equation. Since AutoCAD LT will not run LISP, is there a way to use page setup from the command line. I was asked to include LT user's and I need to find a way to do so with a diesel expression in a menu, before I commit myself.
Rocky Brown
Message 4 of 9
hmsilva
Hi RockyBrown4134,
unfortunately, with a diesel expression, it should not be possible...
Using Auto/Visual LISP, It will be quite easy, but you'll have the LT users problem...
The code DSM_dude has shared, will rename each layout tab, with the TITLEBLOCK TAG value from each layout.
To set as current a 'Named Page Setup' we'll have to use the copyfrom method to copy the PageSetup from the PlotConfigurations collection to the activelayout object.
'I want to be able to set them when I call in my paper border, based on the sheet size'
Are you call in your paper border using some code?
Henrique
Message 5 of 9
RockyBrown4134
Henrique;
Thank you for your thoughts and input, and they are appreciated.
I think I am going to give them a menu pull down for the Page Setup Manager on the Title Block menu. Everything for LT users will be don manually anyway, and this is just another step.
Yes. Setting a variable for the border name (Block name).
                       (setq BDRNAME "BORDER_E")
Then using the following code to insert the border.
                        (command "-insert" BDRNAME INSPT "" "")
I will attach the .lsp and .dcl file so that you can take a look. It's still a work in progress, and has some extra code I have not cleaned out yet.
I haven't quiet understood DSM_dude's cod yet, or how to exactly us it. I have downloaded the cod, but have not had a honest chance to use it.
As far as the COPYFROM method, let me look at the link you sent me.
For the record, I am not that knowledgeable in VBA code. Most of what I have learned has come from you and a few other "favorite" discussion group members. I am very greatfull for all the education that each has given me.
Rocky Brown
Message 6 of 9
hmsilva
Hi RockyBrown4134l
I'm with a very large workload, so, this is just a starting point....
Add to your code this function with one argument, a string with the NamedPageSetup
(defun SetNamePageSetup (name / adoc alayt lst)
    (if (and (vl-position
                 name
                 (vlax-for pltcfg (vla-get-plotconfigurations (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
                     (setq lst (cons (vlax-get pltcfg 'Name) lst))
             (/= (vla-get-name (setq alayt (vla-get-activelayout adoc))) "Model")
        (vla-copyfrom alayt (vla-item (vla-get-PlotConfigurations adoc) name))
and at your's functions, PS-E to PS-A, add a call to the previous function,
i.e.
at the PS-A function, add
(SetNamePageSetup "ANSI A")
at the PS-A-P function add
(SetNamePageSetup "ANSI A PORTRAIT")
at the PS-E function add
(SetNamePageSetup "ANSI E")
Hope this helps,
Henrique
Message 7 of 9
RockyBrown4134
Thanks.  I'll give that a try when I get back to the office.
Rocky Brown
Message 8 of 9
RockyBrown4134
Thanks.
 DSM_dude;
I am not sure if I follow your code correctly, but do I need to add an attribute to the border block with a value for the border size?
Rocky Brown
Message 9 of 9
Jonathan3891
Change "TITLEBLOCK" to the actual block name of your titleblock & "ATT" to whatever attribute you want it to pull the layout name from.
Jonathan Norton
Blog | Linkedin
