Layer lock/unlock toggle
msarqui
msarqui
I was wondering if it is possible to have a routine that will toggle between LOCK and UNLOCK the selected layers. So, the trick is, it must work with SSGET to let the OP select as many objects as he wants, and then lock the layers of those that are unlocked, or unlock the layers of those that are locked.
Thanks for your help.
Marcelo
msarqui
I my research, I found something that could help, but I have no idea how to put this together:
;;;  Returns T if Locked
;;;        nil if Unlocked or not found
;;;        nil if lname is not a string
(defun islayerlocked (lname / entlst)
  (and (= 'str (type lname))
       (setq entlst (tblsearch "LAYER" lname))
       (= 4 (logand 4 (cdr (assoc 70 entlst))))
And here, another one very interesting from Lee Mac. This will lock the selected layers:
(defun c:lck ( / b e i l s x )
  (if (setq s (ssget))
    (repeat (setq i (sslength s))
      (if (not (member (setq l (cdr (assoc 8 (entget (ssname s (setq i (1- i))))))) x))
        (progn
          (setq e (entget (tblobjname "LAYER" l))
                x (cons l x)
                b (cdr (assoc 70 e))
          (entmod (subst (cons 70 (logior 4 b)) (assoc 70 e) e))
  (princ)
Thanks again!
Marcelo
hmsilva
Hi Marcelo!
Quick and dirty...
(Untested)
(defun c:demo (/ i lay layer layers lay_lst ss)
  (setq layers (vla-get-layers (vla-get-activedocument (vlax-get-Acad-Object))))
  (princ "\nSelect objects to toggle LOCK/UNLOCK object layers: ")
  (if (setq ss (ssget))
    (repeat (setq i (sslength ss))
      (setq lay (vla-get-layer (vlax-ename->vla-object (ssname ss (setq i (1- i))))))
      (if (or (null lay_lst)
              (not (vl-position lay lay_lst))
        (progn
          (setq layer (vla-item layers lay))
          (vlax-put layer 'lock (~ (vlax-get layer 'lock)))
          (setq lay_lst (cons lay lay_lst))
  (princ)
Hope this helps,
Henrique
msarqui
Perfect as always Henrique.
It is really nice to have your help.
Thank You
Marcelo
hmsilva
You're welcome, Marcelo!
Glad I could help
Henrique
